Hooker Headers 69 BB with PS. - Team Camaro Tech
post #1 of 11 (permalink) Old Feb 16th, 01, 05:28 PM Thread Starter
Do they fit? help
oger is offline
post #2 of 11 (permalink) Old Feb 16th, 01, 05:52 PM
people have told me that they fit (barely) and others say they have to ding the driver's side header a little. Doug's headers is coming out with some better fitting headers that are supposed to really fit nicely even with power steering. They should be out in a month.
danL is offline
post #3 of 11 (permalink) Old Feb 16th, 01, 06:38 PM
Arrow
I don't know for sure, but Hedmans #65001 do not fit without alot of banging and cussing!!
John D. Smith
69' SS/396
www.geocities.com/kz1000ltd
kz1000ltd is offline
post #4 of 11 (permalink) Old Feb 17th, 01, 08:11 AM
Mine went in my 67 without modification to the headers. The left header had to come up from underneath after I removed the gear box. But once in, it cleared the gear box with no problem. BTW, I have Hooker competion series.
67 Camaro LS6 454/TH400/12bolt 3.73
1989 TransAm 5.7L WS6 W/all the options
www.geocities.com/akfourme/
cardude is offline
post #5 of 11 (permalink) Old Feb 17th, 01, 10:03 AM Thread Starter
The only problem is that the engine sets back 1in on a 69 this appears to be the problem they are made for 68 and 67 but not a 69.
oger is offline
post #6 of 11 (permalink) Old Feb 18th, 01, 02:57 PM
Angry
I'M HAVING THIS PROBLEM RIGHT NOW WITH MY 69 427 CAR. I HAVE HOOKER SUPER COMP HEADERS WITH 2 1/8 PRIMARY TUBES, AND I'M LACKING ALMOST 3/4 OF AN INCH TO EVEN COME CLOSE TO MAKING THIS WORK. IF ANYONE HAS ANY SUGGESTIONS I'M ALL EARS. THANKS BRIAN
[email protected]
brian cornish
brian-69 is offline
post #7 of 11 (permalink) Old Feb 18th, 01, 03:26 PM Thread Starter
You just saved me trying a set of Hookers. Do you have the correct BB frame mounts? I wonder if the headers were made for cars that used SB frame mounts? I have tried Thorleys and Sandersons and they fit about as bad as the your Hookers
oger is offline
post #8 of 11 (permalink) Old Feb 18th, 01, 03:34 PM
I have Hooker super comps in a 69 with a 502 and they fit but the car does not have P/S.
I also have a 69 427 with P/S and just installed Thorley headers and they fit with a little work. Thorley told me it was VERY important to use new GM motor mounts as some repros would not work. Hope this helps.
69 Z28 clone w/502/502
69 Hugger Orange Yenko
http://communities.msn.com/427cruiserphotosite
Yenkofan is offline
post #9 of 11 (permalink) Old Feb 18th, 01, 06:11 PM Thread Starter
I hope you are right about the motor mounts I can't believe that a motor mount can make a difference of over an inch. If you take out the steering box and put the header on and measure the clearence you need it figures out that # 3 tube is 1 inch too close to the steering box
oger is offline
post #10 of 11 (permalink) Old Feb 20th, 01, 04:01 PM
Angry
I HAVE ENERGY SUSPESION MOTOR MOUNTS ON MY 427 69 CAMARO , THEY MAKE TWO DIFFERENT HEIGHTS OF THESE MOUNTS. I HAVE THE LOWER OF THE TWO, I DON'T KNOW IF THIS MAKES MUCH DIFFERENCE.
brian-69 is offline
post #11 of 11 (permalink) Old Feb 20th, 01, 04:10 PM
Angry
I HAVE ENERGY SUSPESION MOTOR MOUNTS ON MY 427 69 CAMARO , THEY MAKE TWO DIFFERENT HEIGHTS OF THESE MOUNTS. I HAVE THE LOWER OF THE TWO, I DON'T KNOW IF THIS MAKES MUCH DIFFERENCE. FROM AS NEAR AS I CAN TELL, THEIR IS ABOUT 3/4 OF AN INCH DIFFERENCE IN WIDTH BETWEEN A MANUAL BOX AND A POWER BOX. MY CAR IS AN ORIGINAL BIG BLOCK CAR SO I WOULD ASSUME THE FRAME MOUNTS ARE CORRECT.
1969 RS/SS 427
E-MAIL- [email protected]
brian-69 is offline
