knock question - Team Camaro Tech
post #1 of 8 (permalink) Old May 16th, 04, 06:07 AM Thread Starter
robert
rolling-robert's Avatar
built myself a new engine, during breakinn, i revved it to 4500-5000 rpm for a split second, then this hard knocking, after cooling off several times the knocking suddenly dissapeared!
i dont know the oil pressure yet, but did i get lucky?? or did i spun a bearing???
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 8 (permalink) Old May 16th, 04, 12:46 PM
Unhappy
RR,
Sorry to hear about this..
Am afraid that all of us over here need a lot more info. then what you have given before any of us can even begin to try to suggest anything in the way of help..
pdq67
post #3 of 8 (permalink) Old May 17th, 04, 01:15 AM Thread Starter
robert
first 15 minutes during break inn went well, then i revved it a second to 4500 rpm, knocking started.
its a very steady knocking, when i rev the engine the knocking increases also.
after 3 start ups, it suddenly disappeared.
since then i never heard a single knock, engine feels like it has power so i think (and hope) it is nothing
Z28 1984
post #4 of 8 (permalink) Old May 18th, 04, 09:11 PM
Charles
drain your oil and change your filter. check both for metal fragments floating around.
you may have had a lifter not pumped up yet. a knocking rod or wrist pin wouldn't "go away", but a lifter pumping up full would.
check your torque convertor bolts too, sometimes loose t.c. bolts make a knocking sound.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #5 of 8 (permalink) Old May 19th, 04, 10:21 AM Thread Starter
robert
thanx, well i checked my oil pressure, it looks good and steady, so ikm damn lucky, i quess
i still dont know why i revved it like that...
Z28 1984
post #6 of 8 (permalink) Old May 19th, 04, 10:48 AM
Kevin
i still dont know why i revved it like that... [/QB]
We all know why...
Kevin
67 RS Camaro 4sp 327, 275HP, AC
72 Chevy C20, 402 BB, AC, Custom Deluxe Camper
KevinImh is offline
post #7 of 8 (permalink) Old May 19th, 04, 04:48 PM
Charles
yes, we all know why you revved it up like that.
you've been a very, very bad boy.
shame on you.
there's a time and place for that kind of behavior.
ABOUT 30 SECONDS AFTER IT'S FULLY BROKE IN!!!
[img]graemlins/beers.gif[/img]
Run269 is offline
post #8 of 8 (permalink) Old May 19th, 04, 06:29 PM
Sean
my moneys on a lifter that bled off and didn't pump back up after you revved it, sounds very much to me like the what happened. you should be just fine. still check your oil and filter for large or lots of metal particles, regardless.
Sean
Franklin D. Roosevelt
68rs406 is offline
