big block install - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 29th, 04, 06:41 AM Thread Starter
i am putting in a 454 can i use the motor mounts that are bolted on the frame from my 350?
RNGZ is offline
post #2 of 4 (permalink) Old Apr 29th, 04, 06:50 AM
Jody
camcojb's Avatar
Yes, but the regular headers won't fit. The factory big block frame pads offset and tilted the big block to gain clearance at the steering box.
Lemons makes a set of headers to fit the big block in the small block location, but they're about $800. a set.
Jody
camcojb is offline
post #3 of 4 (permalink) Old Apr 29th, 04, 06:58 AM
What year's the car?
I beleive 67-68 mounts are availible from the usual suspects. I beleive 69 BBC mounts were not availible when I looked last...
John...
68ragtop is offline
post #4 of 4 (permalink) Old Apr 30th, 04, 04:17 AM
Gary
BBC towers for the 69 are being repopped. Avaliable at all the resto houses. That's the way I'd go. Also, you will need to change the cross member, or modify the one you have. (I'm asuming non-TH400)
Motor mounts (that bolt to the block) can be a problem. If they are too short, the crank pulley will interfere with the front crossmember. My correct mounts are in the car, so I don't think I can get a good measurement. However, I can measure a set that I wanted to use, but they were about 3/8" too short.
Unreal is offline
