Fuel Line - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 14th, 03, 07:42 PM Thread Starter
Lorne
My 67 was originally a 327 210 hp car. The fuel line looks like 5/16. The 327 is now probably about 300hp or so with 350 being the goal down the road. Do I need to go to a 3/8 fuel line? I assume this means changing the fuel sending unit as well as the rest of the line. Thanks
MickyT is offline
post #2 of 3 (permalink) Old Sep 15th, 03, 04:10 PM
I would change it to avoid starvation later on. Perhaps the 5/16" line is okay for your particular application but, if you are like me or if you are like the majority of us in here, then you will never have enough power and later on you will more than likely have to change it anyway. And, yes, you would need to install the correct sending unit as well.
Judd is offline
post #3 of 3 (permalink) Old Sep 16th, 03, 12:42 PM
so, the sending unit needs to be changed too? a bigger job than i thought!
"72 camaro w/"super-deluxe" 350HO/380HP, vortecs, 268XE, Holly 600, RPM, Unilite, Flowtechs, TH350, 3.42 limited slip, ssm subs, 1 1/4" frt,1" rr hellwigs, centerline auto drags ....a 125HP shot of nitrous!!(5/21/04 SOLD!)<br />2003 suburban<br />2000 corvette<br />1995 BMW 530<br />1990 4-runner, lifted, 33's, 4.88's (SOLD)<br />1992 mazda pick-up<br />1984 900 ninja
czar is offline
