cam selection - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 29th, 03, 05:20 AM Thread Starter
I have a 69 with a rebuilt 355 and need help selecting a cam. It has Trick flow twisted wedge heads, performer RPM manifold 9.5:1 pistonsand I want it to be good on the street. Right now I have the Edelbrock RPM cam, but was wondering what would work the best. Any help would be appreciated.
Dysart316 is offline
post #2 of 5 (permalink) Old Mar 29th, 03, 07:39 AM
Smile
Please give the guy's a little time to get around to the site today...
I'm sure there will be a lot of opinions after it gets looked at.. Later, pdq67
post #3 of 5 (permalink) Old Mar 29th, 03, 08:23 AM
Good ol' XE268. Really, for street driving and low-midrange fun that still has a good top end, you can go a bit smaller than that RPM cam. The XE268 is a great street cam. With the Twisted Wedge heads though, they have a great exhaust port so a single patterned cam might be a good choice as well. Comp's 270H is a good street cam. I'm personally running an XE274. It is about as big as I would go on the street for vacuum purposes.
- '68 Chevy Camaro (sort of done, but always subject to improvement)
- '63 Pontiac Tempest (work in progress)
- '72 Datsun 240-Z (back-burner for now)
boodlefoof is offline
post #4 of 5 (permalink) Old Mar 29th, 03, 04:32 PM
Just remember about the piston to valve clearence. The valve reliefs are in the wrong place unless you are using the trick flow pistons made for the heads.
oger is offline
post #5 of 5 (permalink) Old Mar 29th, 03, 05:30 PM Thread Starter
The pistons are not the ones made for the heads. Is that going to be a problem? It is getting close to time to get everything put back together and I would rather get the changes done now. Thanks for the replies.
