327 thougts? - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 10th, 03, 05:01 AM Thread Starter
Have ordered now to my 327cid 210hp:
cam,clear white 270/280 420/430,
lifters,camlube.
Edelbrock 600cfm
Headman headers,2,5"ex.
RPM 7101 intake.
HEI distrobutor.
Everything brand new..
anyone think this will work on a ,before this a good stock engine,??
And estimated hp gain.?
Thanks For Any Thoughts.
ok.
oddrod is offline
post #2 of 4 (permalink) Old Jul 10th, 03, 06:08 PM
Smile
I will hazard a guess and say up to about 240 to 250 hp.. Maybe even 260??
It's your low CR. that is holding you back but at least you aren't over-camming her so she should run quite well, imho..pdq67
post #3 of 4 (permalink) Old Jul 11th, 03, 05:46 AM
when you start building up the old LF7 engine, the heads become a holdup in the quest for performance. They have extremely small intake runners (sub 140cc) and have puny little valves. They can be worked to flow substantially better than they do stock, and a 1.84'' intake valve from a 305 head can be inserted in place of the 1.72'' without much trouble, but all in all you'll be cash ahead to upgrade to a different head if you aren't stuck on originiality.
I'll also say around 260-270 horses tops.
boodlefoof is offline
post #4 of 4 (permalink) Old Jul 11th, 03, 02:00 PM
Steven
Check out my thread "Everything is coming together!" in the performance section. You might find it useful. Im guessing I currently have around 210 rwhp
1968 Camaro
355, Comp XR236R Solid Roller, Air Gap, Pro Systems Double Pumper,
TKO, 10lb flywheel, 3.73 rear, Global West Suspension, Corvette C5 brakes
3098 lbs (and falling!)
sik68 is offline
