cylinder not firing - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 12th, 03, 07:17 AM Thread Starter
On my 67 camaro stock 350//295 hp, engine i have a consistant miss at idle & when engaging trans, in reverse or forward it sounds worse! when accerating it appears that is is not firing on all 8 ! Did complete tuneup, wires, carb rebuild etc, Still has miss. Pulling wires from distributor with engine running 1 at a time , 6 of the cylinders draw the idle down significantly , another [email protected] BUT the back cylinder on the pass, side make NO difference on the idle. It is not firing in that cylinder. Pulled plug & checked spark attached to the wire & there is Lots!! Is a compression test the best thing to locate the problem?? Need a resolution to my problem!!
Rick Stewart is offline
post #2 of 7 (permalink) Old Oct 12th, 03, 07:23 AM
Sounds like a valve (not seating) problem run a compression test
69 Big Block / Hugger Orange Sold
65 Chevelle SS
Black 2010 Electra Glide Classic
Branded is offline
post #3 of 7 (permalink) Old Oct 12th, 03, 11:04 AM
robert
rolling-robert's Avatar
warped lobe on cam
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #4 of 7 (permalink) Old Oct 12th, 03, 04:25 PM
Take the valve cover off and see if it is operating right on that cylinder..
But I would think it would be hammering big time.
pdq67
post #5 of 7 (permalink) Old Oct 12th, 03, 08:10 PM
67 Camaros Rock
Joe Harrison's Avatar
Start with a compression test. You need to start with the basics first, if compressionis fine then start looking other places.
When doing your compression test, if the compressionis low squirt a little oil in the cylinder. If the compression comes up you have ring problems, it will come up a little anyway but if it's very low and comes up to normal or with 10% of other cylinders is when you have a problem. If it does not come up you have a head gasket, head or valve problem.
If everything is normal start looking at the plug, wires, ignition, vacume leaks etc.
Joe
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #6 of 7 (permalink) Old Oct 12th, 03, 09:20 PM
check the firing order. which cylinder drags the engine down a little when you remove the plug wire? is it number 1 or number 4- those are the two cylinders that fire just before and after the number 8 cylinder you say has no spark.
fro the record- the firing order is 18436572, with the rotor turning clockwise as you look at the distributor. the cylinders are numbered 1357 front to back on the driver's side, and 2468 on the passenger side.
it might sound too simple, but it just MIGHT be the problem- it happens to us all, but it's usually 5 and 7 that get mixed up, as they are right next to each other and fire one after the other.
you don't plan sincerity.
novaderrik is offline
post #7 of 7 (permalink) Old Oct 13th, 03, 08:03 PM
check all of the above.
i just had a similar problem on a van i was working on.
it turned out to be an intake gasket leak.
ran myself silly doing tests, watching the valve train, triple checking wires. i had checked for vacuum leaks already, but somehow missed it.
start with firing order (even if you're sure it's right), move to vacuum test, then compression test, then remove the rocker and check the valve train (depending on results). if still stumped, do another vacuum test.
spray carb cleaner around the base of the carb, vacuum lines, all over the intake, especially the edges around the cylinder(s) misfiring, and listen for the idle to smooth out.
ohcscott is offline
