cowl induction - use chevelle type? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 16th, 03, 03:20 PM Thread Starter
I've got a 69 camaro with cowl induction, electrical. It sucks. I've burned out one solenoid and the new one works about 1/4 of the time. VERY bad.
I've seen several chevelles with a cowl hood flap that looks vacuum operated, I'm wondering if I can't manufacture something and adapt a chevelle part to my camaro.
Can anyone with any experience help out?
sbarnes is offline
post #2 of 4 (permalink) Old Aug 17th, 03, 08:36 PM
SY1
My 70 SS 396 had the original set up on it when I bought it back in 1980. Yes the outer hinged door is vacum operated, which is why it opens when the car isn't running or when vacum drops off under high loads. But there is a second door inside the cowl hood that operates electrically off of a switch that the gas pedal contacts if I'm remembering this right. So you still have to deal with the inner door.
"..............what, and get out of aviation??"
SY1 is offline
post #3 of 4 (permalink) Old Aug 18th, 03, 07:55 AM
just get rid of the door and not worry about it. i think it's only real purpose whas to keep gas fumes out of the cowl area when the car's not running. besides, it's just another flow restriction anyways.
you don't plan sincerity.
novaderrik is offline
post #4 of 4 (permalink) Old Aug 18th, 03, 08:32 AM
If you don't have the cowl inducation air cleaner on your car (I looked at your website pictures) then the cowl induction hood, does absolutely nothing for you (except look cool). It won't get anymore air into the engine whether it's opened or closed.
If you remove the flapper, and don't have the cowl induction air cleaner the hot under hood air will come streaming out the cowl instead of going under the car as you drive around. You won't believe how much hotter that makes the inside of your car.
Get the air cleaner before you worry about the valve working. If you've already installed the air cleaner, then you can remove the flapper if you really want to. My solenoid is 34 years old and I've never had it fail. It's only supposed to be open with the gas pedal mashed to the floor, so I can't imagine mine has ever stayed open for more than 15 seconds at ony one time. If your's is staying open more than that, adjust the switch on the accelerator and you may get a longer life out of it.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
