Intake Freeze Plug - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 29th, 04, 05:34 AM Thread Starter
Hi Everyone,
I have a 350 sb motor with an oil filler tube that I would like to plug with a 1.25" freeze plug. The valve covers have an oil filler hole and breather.
Can anyone tell how to install the plug? Does it have to be pressed in and sealed with some kind of sealer? Does the intake have to be removed?
Thanks,
fb250r
fb250r is offline
post #2 of 11 (permalink) Old Dec 29th, 04, 07:00 AM
You can use the rubber type that you tighten up with a bolt that's embedded in the rubber. I had an older Torker intake with the oil fill tube and used this type of plug. I used a polished stainless fender washer and stainless acorn nut to dress it up. These type of replacement freeze plugs are available at most autoparts stores.
sicsD8 is offline
post #3 of 11 (permalink) Old Dec 29th, 04, 03:05 PM
Been a while, but when I did one for a buddy, we installed it from the underside and flush with the top, just used a fingerfull of RVT for sealant.
68 Camaro~LSx ~all motor
post #4 of 11 (permalink) Old Dec 29th, 04, 03:14 PM
JohnZ's Avatar
Install it from the outside, just like you'd install a block freeze plug; that's what the factory did on the '69 Z/28 intake:
[img]graemlins/beers.gif[/img]
JohnZ
CRG
JohnZ is offline
post #5 of 11 (permalink) Old Dec 29th, 04, 04:46 PM
Angry
Cool! John...
pdq67
post #6 of 11 (permalink) Old Dec 29th, 04, 07:55 PM Thread Starter
John,
Nice Z! I'm sure yours came plugged in ‘69, correct?
Where can I get these plugs, and do they have to be pressed in and sealed? Also, does the manifold have to be removed?
BTW, how do you attach images to a post?
Forever grateful,
fb250r
fb250r is offline
post #7 of 11 (permalink) Old Dec 30th, 04, 12:21 PM
JohnZ's Avatar
Originally posted by fb250r:
John,
Forever grateful,
fb250r
It was built just as you see it - it's original. Any auto parts store has the plug, no need to remove the intake to install it.
You need to have your images "hosted" on an internet site, then include the URL to an image in your post for it to show up; you can't attach an image from your hard drive.
JohnZ
CRG
JohnZ is offline
post #8 of 11 (permalink) Old Dec 30th, 04, 03:47 PM Thread Starter
Got it! Thanks John.
[img]graemlins/thumbsup.gif[/img]
fb250r is offline
post #9 of 11 (permalink) Old Dec 30th, 04, 05:02 PM
Drive it in with a socket that will fit inside the cup of the freeze plug and still have room to wobble around a bit, but not a lot. An extension on the socket will help with your aim. Personally, I'd run a thin smear of something like Gaskacinch or even ATV sealant around the inside of the hole in the manifold, then wipe off the remainder after installation.
The only reason you should have to remove the intake to install it is if you drive the plug all the way through!! but I know you won't do that! [img]graemlins/thumbsup.gif[/img]
BPOS is offline
post #10 of 11 (permalink) Old Jan 2nd, 05, 03:47 PM Thread Starter
Angry
What a great idea! Thanks Al, you ROCK!
Frank
fb250r is offline
post #11 of 11 (permalink) Old Jan 2nd, 05, 03:57 PM Thread Starter
Oh, I forgot to ask. Since the oil fill tube is still in place, what’s involved with pulling the Oil fill tube out?
Frank
fb250r is offline
