Big Block Head ID?? - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 24th, 03, 06:17 AM Thread Starter
I finally found and purchased a 454 BB. I am confused about the head identification (casting number 14092360). Mortec http://www.mortec.com/bbc.htm describes it only as open chamber, oval port, Truck. Having no experience with big blocks I donít know if this means I got the ďpeanut port headsĒ. Can someone shed some light on this?
rasp67 is offline
post #2 of 2 (permalink) Old Sep 24th, 03, 03:32 PM
Smile
Ed Staffels book says you do..
Their intake ports are wider then they are tall so are easy to tell.
And by the way, they will support a 454 up to about 5000 or 5500 rpm if you install big valves and do all the stuff you normally would to a set of O/C, -781's or C/C, -251's.. Plus make great low to midrange torque for working a motor!! IMHO...
pdq67
