damaged engine crossmember - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 23rd, 01, 09:54 PM Thread Starter
Thumbs down
I need help locating a good engine crossmember for my '67 Camaro coupe, it has a SB 350, and manual 4 speed tranny
rudyglx is offline
post #2 of 5 (permalink) Old Jul 24th, 01, 09:09 PM
David Pozzi
davidpozzi's Avatar
Try your local Chevy dealer.
# 3899006 is a four speed crossmember for a camaro. they might still have them. I do know they still have the big block turbo 400 crossmember, but it will not fit your trans, the TH 400 is longer.
Nova up to 1974 uses the same crossmember. Firebird may use it too.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 5 (permalink) Old Jul 25th, 01, 04:00 AM
Rick
You mentioned engine crossmember. Is this what you mean or is it the tranny cross member?
Rick Dorion
69 RS Conv,355,M20,4.10's
RickD is offline
post #4 of 5 (permalink) Old Jul 30th, 01, 06:34 AM Thread Starter
Exclamation
Yes, I mean the engine crossmember, the tranny crossmember is ok, Thank you for your reply!
rudyglx is offline
post #5 of 5 (permalink) Old Jul 31st, 01, 09:13 PM
Royce
I think you would be better off replacing the whole sub frame rather than trying to weld in a new crossmember. To weld in the crossmember you will have to be sure it is in the perfect position, which I don't think you can do with confidence without a jig. What is wrong with your current crossmember?
Royce
70 Camaro 383ci
69 Camaro 385ci
91 Camaro RS V8 (305 TBI)
Link to my 70
http://profiles.yahoo.com/camaroman7d
camaroman7d is offline
