Dropping motor with or without tranny attached - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 9th, 04, 09:15 AM Thread Starter
Gary
I removed my crossmember yesterday, because I wanted to make more room to drop my motor with the tranny installed. Anyway, I had to loosen the rear body mount bolts and pry the subframe down, in order to make room to slide the crossmember out.
Is there an easier way, when it comes time to reinstall the crossmember?
Does the crossmember need to be out in order to install the motor and tranny as a unit?
The fenders and core support are in place. Is it easier to install the engine and tranny as a unit, or to install the engine/clutch/bellhousing, and attach the tranny after the engine is installed?
Thanks,
Unreal is offline
post #2 of 3 (permalink) Old Apr 9th, 04, 05:50 PM
you don't say what year you're car is, but on my 67 i have never had to lower the subframe to get the crossmember out. after the crossmember bolts are out and the trans is jacked up as high as it will go, push the right side of the crossmember forward and the left side backward and with a little persuasion, it should come out. you might have to remove the trans mount from the tranny. If you have one of those engine levelers for use with a cherry picker, it is very easy to set the engine and trans in at the same time. I had my crossmember out when i did mine. David
67FREAK is offline
post #3 of 3 (permalink) Old Apr 9th, 04, 06:00 PM
ZZ_430's Avatar
Thanks,
No, just pushed back some will be ok.
I always install everything as an assembly.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
