install timing tape ??- timing now 10* before mark at idle - does this sound right - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 14th, 03, 10:13 AM Thread Starter
I recently purchased a timing tape assortment (MSD) - measured my large balance and used the 8 inch tape
My aftermarket timing marker does not work with the larger GM balancer (its for the 63/4" type)
so my balancer timing mark is before the pointer completely
Tell me if this sounds right
- we found number 1 compression stroke - re-marked zero on balancer in line with timing pointer 0* mark and put the zero on the tape in lined with the new mark
I have a Accell racing HEI distributor - no vacuum advance
Once we started the initial timing was 10* before the zero on the tape - but the engine started right and was idling good
Can this be right ??
once we upped the rpm's it went to about 4* before 0*
if the tape 0 is put on actual zero / #1 compression stroke - does it matter for the purposes of using the tape that we did not put the zero mark on the balancer 0 mark
when we advanced the distibutor to 0* at idle and revved it a bit we got just 4*
Is my distributor shot ?? or have I installed or am reading the tape incorrectly ??
T.K.-85 Camaro-383ci/AFR 210 CNCport-65cc/ProSystem750DP/SRP 7cc dome/Motown int./Comp.S roller 268/275-108*-.720"/.700"@1.6/Big Shot plate/TH-350/8in. conv./4.71 Ford 9in/1.75 super comp/10pt. cage/29.5x10.5x15
caribbean camaro is offline
post #2 of 4 (permalink) Old Jul 14th, 03, 02:18 PM
If your balancer is larger than what the tape is designed for, the marks will be too close together. In other words, 10* will be more like 7 or 8*. The spacing of the marks will be proportional to the diameter of the balancer. Big balancer = marks spaced farther apart.
-dnult
dnult is offline
post #3 of 4 (permalink) Old Jul 15th, 03, 10:49 AM Thread Starter
I am pretty sure that I installed the right size tape for the balancer - its the problem with the rate of advance as seen on the tape - even with my remarking #1 on the balancer to suit the off the mark timing pointer
I am idling at 10* before 0* mark - I want to know if that is just dead wrong as a mechanical possibility
and when I up the revs to 3000rpm steady - I am getting about 4* before 0* mark - thats about 6* advance from idle to 3000
where do I start ??? to get this right as far as reading timing advance
post #4 of 4 (permalink) Old Jul 15th, 03, 01:55 PM
I am idling at 10* before 0* mark ... and when I up the revs to 3000rpm steady - I am getting about 4* before 0* mark - thats about 6* advance from idle to 3000
Sounds like 6* retard to me about 30* short of where you want to be. Should see about 34-40* at 3000 RPM depending on your engine CR and other factors.
-dnult
dnult is offline
