What's the deal?? - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 3rd, 04, 04:32 PM Thread Starter
Does a BB oil dipstick tube pass right in front of the block drain hole so that you can't put an old-fashioned brass petcock on the pass. side??
Do I have to put a square heded pipe plug there instead of a brass petcock??
And the new drivers side brass petcock "T" hit my new poly mount so I did use a brass pipe plug there!! Is this right???
Do I bend the tube???
Sucker's finally coming together slowly....
pdq67
post #2 of 5 (permalink) Old Oct 3rd, 04, 06:03 PM
hehe get off da pc and back in da garage where you belong!!!lol
ok, ya made me get out da book, 68's only one I havem should be same.
Shows dipstick comes out pass side of oil pan, up between pipes 4 @ 6, don't show the drain plug
ok, found powersteering.. going to other post...lol
[ 10-03-2004, 08:21 PM: Message edited by: JimM ]
post #3 of 5 (permalink) Old Oct 3rd, 04, 08:47 PM
Dont bend the tube, the dipstick will be very hard to remove.
I actually just go to GM and buy the stock drain plugs, which a 9/16 socket will fit. Avoid using the square head brass plugs or the allen plugs that come in a frost plug set, as they can be a nightmare to remove once they have been in awhile.
Other options are to get some 90 degree fittings and install them first, then use your petcocks.
Hope this helps.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #4 of 5 (permalink) Old Oct 4th, 04, 01:50 AM
I had the same experience in my dually w/454. I used brass 45* elbows in both locations and oriented them to where the T-handle was away from everything to drain.
Otherwise, as rszmjt suggested, use the hex head plugs, don't tighten them as the gorillas do at the factory........
post #5 of 5 (permalink) Old Oct 4th, 04, 02:07 AM Thread Starter
Thanks guy's!!
I'm on the right track.. I'm using the brass ones BUT will back them out so they aren't "gorilla tight"!
pdq67
