HEI firing order & installation? - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 23rd, 03, 12:01 PM Thread Starter
Need to be sure I'm hooking up the ignition wires from an HEI to a 327 correctly. Is this right:
1.) Engine @ TDC - end of compression cycle.
2.) HEI #1 terminal is the one just below the wire connection housing looking down on the HEI.
Make sure rotor is pointing & this number one
terminal when HEI is installed in engine.
3.) Going clockwise from this terminal #1 is #8,#4,#3,#6,#5,#7,#2.
4.) Hook-up ignition wires from these terminals to correct firing order on engine starting w/ #1 @ front driver's side & you are done!
Thanks for the help,
Sgrouse is offline
post #2 of 3 (permalink) Old Mar 23rd, 03, 12:18 PM
When you are starting from scratch, it really doesn't matter which post on the cap is #1 - if you have it set up as you do, put in the distributor and wherever the rotor is pointing, THAT is #1. Wire clockwise from there, 1,8,4,3,6,5,7,2. For the sake of convenience, I use the post that is just left of center (driver's side) at the front of the cap as #1. I'm pretty sure the factory did it that way, and it really makes sense if your plug wires are cut to length and routed as such. I like to shine a light in the dist hole and make sure the slot on the oil pump drive shaft is in line with where I want the rotor to point so that the distributor completely seats.
If you are converting from your old points dist, make sure you are using a keyed 12 volt power source to the coil. Your old wiring to your points dist used a resistor wire and only delivers around 8 or 9 volts to the coil...not a good set-up with HEI.
One final note...the cylinders on the driver's side, front to back are 1,3,5,7 and on the pass side front to back are 2,4,6,8.
BPOS is offline
post #3 of 3 (permalink) Old Mar 23rd, 03, 01:33 PM Thread Starter
I bought a engine new wire kit from NPD that is set-up for an HEI. Has the plug and everything. Can I skip the wiring directly to the fuse box trick?
Sgrouse is offline
