Engine markings - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 14th, 01, 05:29 AM Thread Starter
I'm looking at a engine and the person that
owns it says it a 302 z/28. I can't find any
markings on it that say engine code MO,MP or
DZ. Where should the markings be? On the right front of motor it says E3314 0 6. On the back left it says 3970010. The heads say
8991492. The crank has 1178 on it and the pistons have L2209A. Its also a 4 bolt main block. To me everything is telling me its a 69 Z/28 302.What do you think? I'd like to be sure before I buy it.
Thanks for all the help now and in the past,
RAGTOP68 is offline
post #2 of 8 (permalink) Old Jan 14th, 01, 10:57 AM
ragtop68,
I don't know what the E331406 is. The 3970010 number can be a 302 ('69) or a 350 ('69 to '80) and can be either a 2-bolt or 4-bolt. Obviously, if it's a Z motor it will be a 4-bolt. The head number 8991492 should be 3991492. These heads were installed on '70 LT1 motors (Vettes and Z's) and were also a '71 and up replacement head. The 1178 crank only came out on the '69 302 ('69 is the only large journal 302) and is steel with a two piece rear mail seal. The pistons I can't help you with that, but I am sure the guys here can help. Sounds like you may have found yourself a '69 DZ 302. Good luck and keep us posted on what you find out.
Later,
Rick
ryork is offline
post #3 of 8 (permalink) Old Jan 14th, 01, 11:03 AM
Except for the heads, that is. The heads should have a casting number like: 3927186, 3947041 and ?
Need a little help here.
Later,
Rick
ryork is offline
post #4 of 8 (permalink) Old Jan 14th, 01, 12:05 PM
JohnZ's Avatar
The pad stamp indicates that the block is a warranty replacement, built in June, 1970 (these were generally supplied as short-blocks, re-using the original heads). The heads are wrong - should be 3927186 (same casting number was used for SS350's, but they used smaller [1.94/1.50] valves, and later SS350's used the 3947041, also with the smaller valves) - the 7186 heads for the DZ engine had 2.02/1.60 valves. The 3991492 heads you have were used on 1973 Camaro/Corvette 350's. Looks like you have a 302 factory replacement short block with heads from a 1973 350.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #5 of 8 (permalink) Old Jan 15th, 01, 12:30 PM Thread Starter
Smile
Thanks for all the help. Looks like I have
a 302 but the heads are wrong. Now I just need to know what heads are better, and what the cc are in both.
Thanks for all the help,
RAGTOP68 is offline
post #6 of 8 (permalink) Old Jan 15th, 01, 03:08 PM
ragtop68,
The heads for a '69 302 are 3927186 and 3947041. Both part numbers should have screw-in-stud, guideplates and 2.02 heads. Both are also 64cc heads. There are many aftermarket heads that will perform better, just make sure you get them in the 64cc version. I personally have the World Sportsman II's, 2.02/ 1.6, screw-in-studs, guideplates and 64cc's - a lot nicer set of heads then the 30 year old ones.
Rick
ryork is offline
post #7 of 8 (permalink) Old Jan 15th, 01, 04:29 PM Thread Starter
Do you know what cc the 3991492 are? I have a set of those with guide plates and screw in studs.Don't know what valves they are.
Thanks,
RAGTOP68 is offline
post #8 of 8 (permalink) Old Jan 15th, 01, 05:13 PM
The 3991492 heads are 64cc and are very similiar to the factory heads on a 302. If you don't care about "numbers matching", then you should be good to go. My information shows that the 492 heads are 2.02"/ 1.6".
Rick
ryork is offline
