396/402 Oil pressure gauge sender mounting alternatives - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 23rd, 03, 09:17 PM Thread Starter
So I bought a nice Autometer electric gauge package, but have run into a problem finding a spot to attach the electric oil sender on my block.
Engine is a 402 with headers, and the standard port on the side of the block next to the oil filter is not useable due to the clutch Z bar interference. Not even enough room there to install the factory fitting.
Are there any other ports on a big block 402 that I can tap a good pressure reading from and attach that fat sender to?
Is remotely mounting an electric oil pressure sender a good idea? I've toyed with the idea of mounting the sender to the firewal and then installing a manual gauge pressure line between the sender and the engine if I can't get the sender mounted on the engine.
Meanchicken
68 SS
ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar
87 Buick Grand National (does 10's)
Meanchicken is offline
post #2 of 6 (permalink) Old Jul 28th, 03, 08:09 PM Thread Starter
Red face
No one has an answer to this?
Meanchicken
68 SS
post #3 of 6 (permalink) Old Jul 29th, 03, 04:10 AM
Cool
You might try drvr side up front of the block. I believe the main oil galley runs the length of the block just above the oil pan rail. At least this is where GM put the sender on my '88 454 Dually, between the engine mount and the front left corner.
post #4 of 6 (permalink) Old Jul 29th, 03, 10:25 AM
Everett is correct. That is where I have my sending unit mounted on the 454. The pressure might be a little lower at that point though vs the port above the oil filter. Just an FYI.
Dean
bilydean is offline
post #5 of 6 (permalink) Old Jul 29th, 03, 09:51 PM Thread Starter
Are you referring to the forward most of the small (about 0.5") hex plugs that run along the bottom of the block above the oil pan?
Meanchicken
68 SS
post #6 of 6 (permalink) Old Jul 30th, 03, 02:01 AM
Cool
Yes.
