Trying to remember what oil on spark plugs threads means??? - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 10th, 04, 10:53 AM Thread Starter
kel
My number 8 spark plug keeps getting major oil on the plug and threads.
Time for a ring job? Worn out valve seals? I forget what this is a sign of. [img]graemlins/boring.gif[/img]
Any help is appreciated! [img]graemlins/beers.gif[/img]
2007 Dodge Charger
Pursue Perfection..Settle For Excellence!
kel is offline
post #2 of 4 (permalink) Old Apr 10th, 04, 05:13 PM
Don't overlook a leaky valve cover. If oil runs down around the plug, oil can wick up the threads. But you can usually tell which direction the oil is coming from if you look closely.
dnult is offline
post #3 of 4 (permalink) Old Apr 15th, 04, 10:33 PM
if no leaks are found bad valve guides or seals are probably the culprit
Eric
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #4 of 4 (permalink) Old Apr 16th, 04, 07:04 PM
D
Kel, This may help. Good reference tool.
http://www.verrill.com/moto/sellingg...colorchart.htm
1969 Camaro X11
L14 307ci/200HP base V8
PowerGlide
Factory AC
62,000 Original Miles
Prior 1968 Camaro
210HP Turbo-Fire 327-2V
PowerGlide
Domano 68 is offline
