PCV Valve connection question - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 2nd, 03, 07:30 AM Thread Starter
Send a message via AIM to Scott Vinzant
I see that there is a blocked off vaccum nipple on the back side of my Edelbrock Torker intake, right below the mounting flange for the carb. THere is also a vaccum port on the carb, this is where the PCV valve was connected. My questions is: Can I block off the carb fitting and connect the PCV valve to the manifold fitting and accomplish the same thing? I would think they are both at the same vaccum "potential" of full manifod vaccum.
Lemme' know your thoughts...
Thanks guys!
<a href="http://amy.vinzant.home.mchsi.com/69camaro.html" target="_blank">'69 Camaro</a>
Scott Vinzant is offline
post #2 of 3 (permalink) Old Aug 2nd, 03, 11:28 AM
Bill
Scott,
Either fitting will work fine.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 3 (permalink) Old Aug 2nd, 03, 11:44 AM
The PCV is usualy hooked up to the carb base while the manifold fitting is used frequently with power brakes and other vacuum accessories.
-Mark.
stingr69 is offline
