Which Engine Frame mounts do I have? - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 4th, 04, 02:24 PM Thread Starter
I am restoring a 68 and I dont know anything about its history. it has no drivetrain in it, and Id like to find out what I have mounting stuff. The frame mounts are on the car but I have no idea if they were big block or small block. Any way to tell? I guess while Im at it, any way to tell if my front end is setup for small or big block? (springs etc).
Bob
Bob D is offline
post #2 of 11 (permalink) Old Sep 4th, 04, 04:12 PM
Brandon
Bob, I believe you'll find part #'s on the mounts.. post those back and someone will chime in on which they are for if they dont already post the #s for which is which.
Radiator will be a clue as far as size and how upper hose connection is, how heater connections are on fire wall, in center top of the suitcase is big block, to drivers side of case is small block.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 11 (permalink) Old Sep 4th, 04, 04:40 PM Thread Starter
thanks Ill check out the numbers in the morning. There is no radiator or any drivetrain components. Everything from the firewall forward is gone with the exception of the frame rails, suspension.
I do now have a big block to put in it and just want to make sure I have all the right suspension parts so i dont drop it in and have it scraping the ground
Bob D is offline
post #4 of 11 (permalink) Old Sep 4th, 04, 04:58 PM Thread Starter
I just looked, the numbers are a little vague, but it appears to be 3945508 for the passengers side.
Bob D is offline
post #5 of 11 (permalink) Old Sep 4th, 04, 05:31 PM
Brandon
I think that may be for a small block but not sure. The two should be the same height if they are small blocks, and a bit higher on the drivers side if they are big block mounts. Heres some more info on purchasing.
If you need the frame mounts for a sb motor. go to this site:
http://www.nationalpartsdepot.com/ca...camarocat.html Click on engine parts
The closest store to you is in Michigan (800)521-6104
You'll be able to look up #'s C-0029-7A, 8A. These are the right and left mount for a 67-69 camaro small block engine. $16.95 ea
Motor mounts. same addy
#'s
Repro - C-0027-2A $9.95
orig - C-0027-2 $49.87
BB mount for 67-68 C-0029-6AP $64.95 for the pair
396 Motor mounts C-0027-5 (orig) $65.56
C-0027-7A (repro) $12.95
Nantooch is offline
post #6 of 11 (permalink) Old Sep 5th, 04, 01:44 PM Thread Starter
Ok yup, looking like small block stuff. I guess with that in mind, its safe to assume the rest of my suspension is setup for small block? What else would I need to change out, just the springs i would guess, right?
Bob D is offline
post #7 of 11 (permalink) Old Sep 5th, 04, 05:41 PM
Brandon
That would depend on what motor you want to put in.. Springs will likely be fine if all else shows as sb stuff. If your going to go to a big block then most of the stuff mentioned will have to be upgraded to the big block equip.
Nantooch is offline
post #8 of 11 (permalink) Old Sep 5th, 04, 06:06 PM Thread Starter
Yes, Im sorry, I failed to mention, I have a 427 for the car that i will be putting into it. So far Im just thinking motor frame mounts springs.
Bob D is offline
post #9 of 11 (permalink) Old Sep 5th, 04, 08:08 PM
Brandon
In that case, you'll have to replace
front springs C-7412-129 $54.95pr
Radiator $$$$$
Radiator fan shroud C-1277-03A $79.95
Radiator support C-1270-1A $69.95
Heater W/O AC C-8854-4 $49.95
Heater Core Case assy. C-8857-1A $79.95
Tranny crossmember
for turbo 400 (repro) C-4081-2A $49.95
(orig) C-4081-2 $72.29
Nantooch is offline
post #10 of 11 (permalink) Old Sep 6th, 04, 02:15 PM Thread Starter
Ahh great thank you for the info. In looking around I dont see a big block rad support vs a small block one though... am I missing something?
Bob D is offline
post #11 of 11 (permalink) Old Sep 6th, 04, 02:34 PM
Brandon
Nope, interchangable part.
Nantooch is offline
