Help with stutter! - Team Camaro Tech
post #1 of 1 (permalink) Old Aug 7th, 03, 04:50 PM Thread Starter
Rodney
Exclamation
I am having a problem on my 69 camaro with it cutting out or stuttering between 2500-3000rpm or part throttle. It is fine light throttle or full throttle but when going part throttle it is almost like it is loading up on fuel, but have changed the jets in the primaries 3 times to try and fix it. The funny thing is that it only acts up when the car is at operating temp(about 180*).
I am running a Summit HEI dist.(bought new just over a year ago), MSD in cap coil(was on the car when I got it at least 6yrs), MSD 6al(just took out of box in early 03 to install). I've been getting a carb built for the car and got it installed last week and have started having weird problems since(carb was the only thing changed). Now the car won't shut off, have to put it in gear after turning the key off. Never had this problem before now(not the neutral safety switch). I think it had the same hesitation/flood-like feel with the other carb, but thought it was the Street Avenger carb. The tach jumps around after the car is shut off, but works fine.
Today I tried changing coils, did the same thing after it warmed up. So I have narrowed it down to a bad distributor or faulty MSD. I think I'll try and by pass the 6al tomorrow and see if it cures the problem. I have a buddy with a mustang and is complaining of a very similar problem and just bought his 6al earlier this year.
Has anybody had a similar experience? Or any suggestions?
69 RS Camaro (383,700r-4,12-bolt w/4.11s)
79 WS6 Trans Am (406SBC,factory 4-spd,3.23 posi)
87 GTA Pace Car Clone (350TPI,700r4)
97 Bonneville SSE 40th Anniv. (3800 V-6,All Power)
Check out my site at
wildkatz is offline
