Yes or No question about ported vacuum - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 23rd, 04, 07:32 PM Thread Starter
When vacuum advance is connected to ported vacuum does it add that timing at all at WOT? I was told that it cannot add timing at WOT because there is not any vacuum but I would think it could pull it a little, so whats the answer?
nitrous383 is offline
post #2 of 5 (permalink) Old Apr 23rd, 04, 08:01 PM
SS
No vacuum advance does not add timing at WOT. I run direct manifold vac to adv unit for more timing at idle and works well for my cam and improved idle characteristics. SS
406, TKO 600 and 12 bolt posi.
railing68 is offline
post #3 of 5 (permalink) Old Apr 24th, 04, 10:07 AM
JohnZ's Avatar
Doesn't matter where it's connected at WOT - there's no vacuum there; only matters at idle. [img]graemlins/thumbsup.gif[/img]
JohnZ
CRG
JohnZ is offline
post #4 of 5 (permalink) Old Apr 26th, 04, 03:27 AM
Marc
And about mpg at idle and low RPM cruising speeds? which set up gives better mpg?
Camaro 1968, propane 327ci, Big Brake, Hotchkis, T56
Marc is offline
post #5 of 5 (permalink) Old Apr 26th, 04, 05:20 AM
Full manifold vacuum to your vacuum advance will improve the idle efficiency. At cruise the ported vacuum signal is equal to the manifold vacuum signal so it's a tossup.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
