69 BB Frame and motor mounts in a 67 - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 15th, 04, 11:35 AM Thread Starter
I've done a lot of searching on this subject but I haven't found an answer to my question. I've got a 67 Camaro with a BB 396 in it. I don't think it's sitting onthe correct motor mounts. Would the 69 BB frame mounts work on my 67 with the 69 motor mounts with out any clearance issues? Or should I stick with the 67 BB stuff? Also I've read on here that the Repro stuff is not near what the original stuff it. I looked at D&R and they have Ogriginal 67 Frame mounts for $350.00 for the pair. That seems a little crazy for some stamped steel brackets.
Thanks for taking the time to answer my questions.
Thanks,
Ryan
Rynos67 is offline
post #2 of 2 (permalink) Old Oct 15th, 04, 02:25 PM
Look at National Parts Depot, Livonia, MI!! I bet you can get just what you need and at not all that bad a price!!
And imho, re-pop's are fine if you buy the correct ones as well as correct rubber or poly mounts too.....
pdq67
