71-72 350 heads on my 327 - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 10th, 03, 09:45 AM Thread Starter
Kevin
I changed the head on my 327 about 10 years back and I just found out that the heads I replaced them with are from a 71-72 350 engine. My questions is what is the recommended spark plug I should be running in these heads. The old heads took a R45TS or R44TS if I remember correctly.
67 Camaro rs
327/TH350/3.73 8.5" 10 bolt
67 Camaro rs/350 HO(est. 401hp)/4L80E/8.5" 10 bolt 3.73
Sixty-Seven rs is offline
post #2 of 3 (permalink) Old Mar 11th, 03, 02:00 AM
Cool
I would say it depends upon the engine's state of repair.
The 45's are a step hotter than the 44's. Forty-five's are middle of the road heat range with 46 the hottest and 43 the coldest. I have seen 42's.
Most engines run a 44, however, depending upon age and oil seepage into the combustion chamber, a hotter plug may be warrantied. This hotter heat range will keep the electrodes cleaner within reason. If the engine is burning a quart of oil, say, every 500 miles, then, no hot spark plug is going to keep itself clean to fire.
Its trial and error, see what the book suggests for the year of block, if its 44's, try them out. After a couple thousand miles, pull the plugs to inspect the electrodes. If they are anything but tan in color, then change to 45's.
Everett#2390 is online now
post #3 of 3 (permalink) Old Mar 12th, 03, 05:40 PM
Tim
Send a message via AIM to murrayo
My .02... I've been using Autolite #25 on my 041 heads. They are an extended tip plug. I don't know if that really makes a difference but it makes sense that putting the spark more in the middle of the chamber would help things
Tim
Timo 67 RS/SS 350 Camaro
murrayo is offline
