waterpump!!! - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 15th, 03, 06:09 AM Thread Starter
robert
rolling-robert's Avatar
how can i check if my waterpump is still good?
i have it here in my hands, pulled it of engine
i opened it from the backand see this rotor with a spring behind it...
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 3 (permalink) Old Aug 15th, 03, 06:49 AM
If it wasn't leaking or noisey when you took it off, then I would say It's OK. But if it shows signs that it was dripping (you can tell by the little hole under the housing directly under the impeller drive shaft) You may see a little water/antifreeze stain there. If you are doing a new engine and your pump is any more than a year old, I would have it rebuilt or replaced. If It's easily accesible and not too much work to remove you might want to use it, but pumps aren't that expensive. (Don't know about the Netherlands) I would replace it if It's not nearly new.
But you never know! The old one might last longer than a new one! One of lifes many misteries.
GMJim is offline
post #3 of 3 (permalink) Old Aug 15th, 03, 06:58 AM
Rick
Since it's off, can you put it in a vise or something to hold it? The, with the fan blade one, see if there is any side-to-side play which will indicate bearing wear => replace it.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
