intake gaskets - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 24th, 03, 05:22 PM Thread Starter
Zach
the driver side gasket on my intake manifold seems like it gets soaked with a little bit of oil every time i drive the car. thought maybe it was the valve cover gasket, didn't look like it was leaking when i looked at it, changed it anyway though. drove it again, put my finger on the gasket, and its a little slimy again. bad intake gasket? would oil get sucked up there and soak the gasket? car isn't running any different. this only started about a week ago. if it is the gasket, i'll take any suggestions on an intake set and how to install it. its an edelbrock performer intake on a 350.
69 Camaro - LeMans blue w/ black vinyl top - 350/TH350
69nj350 is offline
post #2 of 6 (permalink) Old Sep 24th, 03, 06:42 PM
Did you make sure your bolts are torqued down right on the intake. If so did you use silcone around seal that goes around the water jackets part of the head. Also use some gasket ashhesive to hold it down if you havent tried that already. Felpro makes great gaskets.
69ssCamaro4a17yrold is offline
post #3 of 6 (permalink) Old Sep 25th, 03, 05:41 AM Thread Starter
Zach
everything was torqued down and installed right, the gasket has been on there for about 5 years. no problems until now.
69nj350 is offline
post #4 of 6 (permalink) Old Sep 26th, 03, 11:30 AM Thread Starter
Zach
well i'm pretty sure its the intake gasket, so i think i'll go ahead and change it. it's been a long time, but i think i used fel pro 1256 gaskets when it was put together. it was actually put together by a mechanic i knew really well, watched most of it. i believe he used rtv on the front and back of the block, looks like thats the best way from the archives too. only other problem is that i don't own a torque wrench, can the bolts be torqued pretty well by feel of the hand?
69nj350 is offline
post #5 of 6 (permalink) Old Sep 28th, 03, 06:54 AM
robert
rolling-robert's Avatar
be safe and borrow, buy or steal a torquewrench.
but i must admit, i did it by hand also.
but its kind of dangerous, if u torque too hard, u will ruin the threads
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #6 of 6 (permalink) Old Oct 1st, 03, 11:31 PM
69nj;
are you sure that the baseplate of your carb isn't dripping gas down onto the intake gasket?
this happened to me and it looked just like you describe!might save you pulling the manifold just to let it run til good and warm then shut off and cool down while watching carefully at the screws that go into the shaft that holds the butterflies.
good luck!
Eric
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
