Speed Demon - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 31st, 03, 03:56 AM Thread Starter
Will a stock big block drop base air filter fit a speed demon with vac. secondaries and electric choke ????????????
RSSS is offline
post #2 of 5 (permalink) Old Mar 31st, 03, 04:23 AM
I am not sure if mine is a drop base or not I'll check tonite.
it does fit under a cowl hood though
on a 454 proper mount and a RPM airgap intake.
"Drive it like you stole it"
2000 SS camaro daily driver(wifes)
Oncea3Fan is offline
post #3 of 5 (permalink) Old Mar 31st, 03, 06:05 AM
DjD
DjD's Avatar
You may find this thread useful... https://www.camaros.net/forum/ultimat...c;f=4;t=006630
...Dennis
DjD is offline
post #4 of 5 (permalink) Old Mar 31st, 03, 06:30 AM
now that I reread the question,I recall cutting out a small section of my base to clear the linkage.I have a run of the mill aftermarket aircleaner= $19.95
sorry
post #5 of 5 (permalink) Old Mar 31st, 03, 07:06 AM
Rick's 1st Gen. has a stock repro of a open element 14" base. ($48 - # EP-102) States fitment '67-'69. I have the 625 Road Demon. This base fits nice and low, has a very short neck, correct breather tube, that actually clears the linkage on my Demon and should yours. Check a good Chevy swap meet, a vendor will always bring one along or better yet, if you are lucky enough to have a nearby Camaro/Chevelle/Nova/El Camino restore vendor to dry fit and see for yourself. Good luck, not sure if this answered your question or not. Dan
'67 Camaro rs, L30-327/275.
no bail4u is offline
