coolant leak - Team Camaro Tech
post #1 of 11 (permalink) Old Jul 21st, 03, 10:18 AM Thread Starter
I have a small but presistant coolant leak at the intake manifold where the thermostate is. I always seem to have a small puddle of coolant on the intake. I'v noticed the guy I bought the car from not only installed a gasket but has a generous amount of sealant also applied. Someone told me this is a comon leak problem. Does anyone else have this as a problem? Any suggestions or tricks before I take it off and put a new gasket on?
HO69 is offline
post #2 of 11 (permalink) Old Jul 21st, 03, 10:50 AM
DjD
DjD's Avatar
Some do, some don't. It doesn't need to be a problem... Both surfaces need to be clean and flat. Then get a housing gasket with the blue ring built into it (chevy dealer or corvette or camaro shop) Get a cast thermostat housing (stay away from chrome) paint it with an alumablast or chev orange color to match your intake and bolt it up without any sealer at all...
...Dennis
DjD is offline
post #3 of 11 (permalink) Old Jul 21st, 03, 10:54 AM Thread Starter
OK, I have the cast thermostate housing already. I will get the gasket with the built in blue ring. Hopefully that will do it, don't like the idea of any sealant being used. THANKS!
HO69 is offline
post #4 of 11 (permalink) Old Jul 21st, 03, 11:31 AM
Kevin
KevinW's Avatar
What I use is the regular paper gasket. Straighten the cast housing by wet sanding (around 400 grit) it on a piece of glass. This will level the housing. Then take permatex non-hardening gasket sealer and put a THIN coating on both sides of the gasket (or metal, doesn't matter, just get sealant on both mating surfaces!) I just evenly smear the sealant with my finger until just a coating remains. Then tighten. A very little amount of sealer oozes out. This has not failed me yet! [img]smile.gif[/img]
Kevin
Kevin
KevinW is offline
post #5 of 11 (permalink) Old Jul 21st, 03, 11:33 AM
I use the plastic gasket with rubber o ring built into bottom/top. Available at autozone.com !! BTW, its installed DRY, no sealant AT ALL!!
FELPRO 35562T for $4.29 Autozone
Felpro 35562 website link
and
Brian Lewis is offline
post #6 of 11 (permalink) Old Jul 21st, 03, 11:59 AM
Vintage 68's Avatar
Just follow the great info in all three of the replies!
1.) Use a good Cast Housing.
2.) Make sure it is reasonably flat by trueing on a piece of 1/4" glass or surface plate.
3.) Use the new FelPro gaskets!
These 'Printed-Seal' type gaskets are the $hits for Intake and Thermostat applications! Fords have a bad leak problem with their cheap cast aluminum housings and these gaskets work perfect for them too.
Now if they'd only make them for Water Pumps...
1968 Convertible
Some trucks
Vintage 68 is offline
post #7 of 11 (permalink) Old Jul 21st, 03, 12:22 PM
I know what you mean about gasket sealer. Many people over do it by putting it everywhere. The thermostat housing is one of the few places I put sealant. I usually use the yellow gorilla snot (I think it's actually a 3m product). It's almost like rubber cement. Stays sticky. Maybe what Kevin was talking about.
-dnult
dnult is offline
post #8 of 11 (permalink) Old Jul 22nd, 03, 12:55 AM
I think he meant Permatex #2 non-hardening sealer. Good stuff, along with Permatex #3.
jimfulco is offline
post #9 of 11 (permalink) Old Jul 22nd, 03, 06:14 AM
Kevin
KevinW's Avatar
Angry
Right, permatex #2. It's too much trouble to chase down all the fancy stuff, when the old fashioned paper one is included in the kits and the permatex is right in the top drawer [img]smile.gif[/img]
Either solution will work, just make sure your housing is not warped.
I too am saddened by the "goop blue RTV everywhere" people. But it does have it's uses. Just use the correct sealer for the application and use it sparingly. Too much is never the answer
Kevin
Kevin
KevinW is offline
post #10 of 11 (permalink) Old Jul 22nd, 03, 06:18 AM
Vintage 68's Avatar
"Too much is never the answer" - except when you find out how much that NOS part you really need is! [img]graemlins/waving.gif[/img]
I only use the 'Blue goop' on our Blue oval cars. The others get the "good" stuff!
1968 Convertible
Some trucks
post #11 of 11 (permalink) Old Jul 23rd, 03, 01:33 AM Thread Starter
WOW so much good advice. I will check for straightness and sand if necessary, then use the gasket with the blue ring. Hopefully this will do it, if not then the goop will come out. THANKS ALL!
HO69 is offline
