Cam thrust washer - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 14th, 04, 08:39 PM Thread Starter
454 9+ compression street use 6500 or less with hydraulic cam .540/.540 296/306 114 lobe sep, HD springs, cast flat pistons, stock rods/stroke, stock guide and rockers.
Do I need a cam thrust washer for this or just put the cam gear on and degree it properly? End play is fine.
jobberone is offline
post #2 of 5 (permalink) Old Dec 15th, 04, 04:36 AM
With a flat tappet cam, the slight angle cut into the lobes to rotate the lifters will keep the cam back where it belongs. Roller cams need a thrust washer or button
post #3 of 5 (permalink) Old Dec 15th, 04, 06:24 AM Thread Starter
Thanks Jim. That's the information I had but two people trying to help were telling me otherwise. Certainly makes things simpler for me. Have a great holiday.
post #4 of 5 (permalink) Old Dec 15th, 04, 07:43 AM
Bruce
I put a button my BBC with a new Comp Cams XE294H cam and from what I've been told by the tech's at Comp Cams, this is why a lifter broke and went through the side of the block.
They also made the same comment Jim made, so I've told myself that the button is in the trash.....
69 Camaro, 496, 10.34 @ 134.77 mph.
bruce69camaro is offline
post #5 of 5 (permalink) Old Dec 15th, 04, 10:28 AM
Matt
A thrust button and thrust washer are different things. You don't want a thrust button with a non roller cam. But you can put a thrust bearing behind the cam gear on a non roller cam, but you also have to have the cam gear with the recess machined in. This will save wear on the front surface of the cam journal.
Bing
1923 T-bucket 406ci
1956 Chev 150 2dr sedan 302ci
1965 Chev Malibu 2dr hdtp 496ci
1967 Chev Camaro 327ci
2001 Harley XL1200C
2002 Chev 2500HD
2005 Chev 1500
2007 Harley FLSTC
