hesitation and backfire - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 28th, 01, 08:05 PM Thread Starter
I have a 73 camaro and 79 z28. The 79 z28 has no engine in it but i am going to put the 73's engine in it. Anyway the engine is a 350 and for some reason recently it has been hesitating and backfiring real bad when i step on the gas and no one I know has been able to figure it out.
P.S. it is not the timing or choke.
fordthrasher is offline
post #2 of 4 (permalink) Old Mar 29th, 01, 05:45 AM
Has the ditributor been pulled lately? It sounds like it's off by a tooth, or timing chain jumped.
383 Speed-O-Motive stroker kit with Speed Demon 750, RPM intake,Proform HEI dist.MSD6a box,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves,64cc,TRW forged pistons with 10.7:1 compression, Comp Xtreme 284 cam,Crane pushrods, Comp Cam 1.6 full roller rockers,ATI damper, 40 series Flowmasters, 4.11 gears with TH350 and 3000 stall.Powertrax NoSlip Locker
Tracy Focht is offline
post #3 of 4 (permalink) Old Mar 29th, 01, 10:59 AM
How about, have you tuned it up recently and accidentally swapped two spark plug wires. Just a thought.
bilydean is offline
post #4 of 4 (permalink) Old Mar 31st, 01, 08:13 PM
Watch your timing mark with a timing light...does it move around a lot? If so, the timing chain is shot...and if thats the case, better get it fixed before it lets go and valves start touching pistons.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
