Help! Fender is hot to touch! - Team Camaro Tech
 1Likes
  • 1 Post By dhutton
post #1 of 13 (permalink) Old Aug 22nd, 16, 04:23 PM Thread Starter
Tony
This is really weird. I was finishing up breaking in the cam on my new crate engine. The engine was running at 2200 RPM for about 10 minutes. Within 5 minutes the passenger side fender got so hot I could not put my hand on it for longer than 2 seconds. I could feel hot air blowing that direction from the fan and radiator area. I am running headers and everything is brand new. I'm hoping this would not be an issue if I am driving down the road and air is cooling the fender and radiator but I have never seen or even heard of this before. I'm about to take the car to the paint shop in a week or two and I don't want the paint on the fender to get so hot that it bubbles or peels...
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #2 of 13 (permalink) Old Aug 22nd, 16, 05:24 PM
Re: Help! Fender is hot to touch!
Ideally you would use a large fan to direct air into the radiator and engine bay when doing something like that. At least I do. Same when I am charging AC etc.
It should be fine when you are going down the road.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 13 (permalink) Old Aug 22nd, 16, 06:12 PM
Factor in the off timing if you just cranked up and ran by ear. 2200 rpm in 10 min sounds about right. Having headers the heat would tend to rise behind the fender aprons, unless you were running fender well exit. Pun intended.
TC # 349
zdld17 is offline
post #4 of 13 (permalink) Old Aug 22nd, 16, 11:23 PM
Smile Re: Help! Fender is hot to touch!
Is your battery grounded to the fender and not the engine block as it should be ?
TJS69 is offline
post #5 of 13 (permalink) Old Aug 23rd, 16, 04:32 AM
As suggested, fender is going to get hot with no ambient air moving from a fan in front of Camaro.
Headers are a great heat radiator, more so then cast iron manifolds.
Your temp gun will go to max reading and might get stuck there...
post #6 of 13 (permalink) Old Aug 23rd, 16, 06:03 AM Thread Starter
Tony
No. I am grounded to the engine block. Do you have a picture of the fender ground that I should have? I thought the AIM showed a ground to the engine block...no?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #7 of 13 (permalink) Old Aug 23rd, 16, 06:18 AM
It would take a huge amount of current to make a fender hot to the touch. Much more than your battery or alternator could produce. It would likely blow a hole in the fender at the point of contact long before the whole fender would be hot to touch.
Moonpie likes this.
post #8 of 13 (permalink) Old Aug 23rd, 16, 08:08 AM
Mickey
Moonpie's Avatar
I've seen headers get red-hot in that time frame on a dyno or the rollers for emissions testing. That would radiate a ton of heat but not to be able to hold your hand on the fender seems really beyond that.
Moonpie is offline
post #9 of 13 (permalink) Old Aug 23rd, 16, 08:21 AM
They do get hot. I remember when first design of ceramic coated headers came on market, the coating flaked off during camshaft break-in. Even the old Blackjack headers with plasma-spray alum.
No airflow and fender(s) gotten hot enough to literally fry an egg.
Watched a friend do this and his egg was cooked - both of them - the header set and the egg - solid yolk.
post #10 of 13 (permalink) Old Aug 23rd, 16, 11:03 AM
click's Avatar
Your battery should have a huge wire that gets grounded to the block and a pigtail that gets grounded to the fender right above the battery. You should have both.
click is offline
post #11 of 13 (permalink) Old Aug 23rd, 16, 04:23 PM
Grounding to the block IS correct. Sorry, if my wording was confusing.
TJS69 is offline
post #12 of 13 (permalink) Old Aug 23rd, 16, 04:53 PM
scblucam's Avatar
Seen red hot headers on cam break ins many time. Get the timing right and not so bad. Big fan at the radiator excellent idea.
68 302 M20 - 85 IROC Z
scblucam is offline
post #13 of 13 (permalink) Old Aug 23rd, 16, 06:42 PM Thread Starter
Tony
Roger that!
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
