reccomended fuel line - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 14th, 03, 08:41 PM Thread Starter
What is the recommended fuel line needed for a 500 hp 383? This system wiull have no return line. THe car has the stock small block factory set up. I think it is 5/8 does that sound right?
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #2 of 4 (permalink) Old Sep 15th, 03, 06:55 AM
Codi's Avatar
Arrow
-You are probably running a 3/8 inch line. It MAY be adequate for your engine. All of the big blocks were 3/8 so I don't really see a problem, although they did run a return line. With what you are running, I would consider a return line. They are available and not to expensive. Your tank unit will need to have a return line added to it.
Daddy's Hot Rod.
Codi is offline
post #3 of 4 (permalink) Old Sep 15th, 03, 11:28 AM
Please correct me if I am mistaken but, I thought that the return lines were used on cars with Rochester carbs? I would just use the 3/8". My buddy has a 455 in a 71 Ventura and went with the same line (3/8").
Judd is offline
post #4 of 4 (permalink) Old Sep 15th, 03, 06:15 PM
I use the stock 3/8" on my 468ci with about 550HP, no problem. No fuel starvation issues at all....
1969 Camaro - 468ci/700r4/3.73 - 11sec and drove her home.
mikestr is offline
