strange fuel color - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 13 (permalink) Old Aug 25th, 16, 06:52 PM Thread Starter
Chris M.
strange fuel color
Team Camaro,
During the process of troubleshooting a timing problem, I noticed a tiny dribble of fuel leaking from the secondary feed line to the carburetor. It had a strange orange/brown color. To further investigate, I disconnected all fuel lines from the tank to the carburetor and collected what you see in the glass on the right. To compare, I siphoned some gas from the tank and put that in the glass on the left.
Before I tried turning over the engine a couple months ago, I flushed the entire fuel system with detergent. Are my fuel lines rusty? That strikes me as odd, because I figured all fuel lines on the market ought to be stainless steel. Is there something else going on?
What do you think?
resto_noob is offline
post #2 of 13 (permalink) Old Aug 25th, 16, 07:27 PM
Re: strange fuel color
Based on what you are saying, I think you have old fuel (darker )in front of new. I would try to purge all the fuel into a container that you can look at closely. I am thinking you will find the newer fuel but you may also be finding trash or rust as I don't think fuel lines were stainless from the factory or at least I haven't seen any, I think once you strain the fuel via fuel filters, you should be getting clean fuel into the carb.
Your climate is or should be dry with not much water getting into service station tanks, but there are some stations that have issues.
With the E85 fuel around the corner , I would consider replacing fuel lines with the newer poly type unless there are safety concerns, use stainless.
TC # 349
zdld17 is offline
post #3 of 13 (permalink) Old Aug 25th, 16, 08:44 PM Thread Starter
Chris M.
The fuel system was dry when I got the car, and I flushed all the fuel lines with detergent before filling the system with new gas about two months ago.
post #4 of 13 (permalink) Old Aug 25th, 16, 08:52 PM
Detergent may have caused rust. Being dry may have caused surface rust inside tank, Be safe , make sure tank is rust free, fill and raise rear of car and let gravity flow into a container say just off the fuel lines, install filters, maybe one before fuel pump and one after to carb.
You don't know what previous owner did with the car, could have been sitting outside with cap off. Never know. If in doubt, remove tank and pull gauge and inspect. Maybe have it steam cleaned?
Maybe others may have a different opinion but that's my free one.
TC # 349
zdld17 is offline
post #5 of 13 (permalink) Old Aug 25th, 16, 08:57 PM
DjD
DjD's Avatar
Are you using a fuel filter? Is it new? If that isn't it, I'm going to take a wild shot at this and suggest changing your fuel pump. The thought being crankcase oil is somehow seeping into the fuel through the pump...
Oh, not all fuel lines are stainless, you have to pay extra for stainless replacements and they are about 2x the price.
...Dennis
DjD is offline
post #6 of 13 (permalink) Old Aug 26th, 16, 09:07 AM Thread Starter
Chris M.
Good words, fellas. Thanks for the help. I think I'll start with the fuel pump to make sure that oil from the crank case isn't somehow seeping in to the pump and contaminating the fuel. Aside from that, maybe replacing the fuel lines to rule that out as well.
post #7 of 13 (permalink) Old Aug 26th, 16, 09:19 AM
Just a note, the an internal leaking pump has been known to leak fuel into the crank case oil as well , there are two diaphragm inside, so replacing the pump would cure those problems.
It may be a good idea to remove the carb and turn upside down to remove whatever fuel you have in it. I believe you mentioned it was the carb where you noticed the darker fuel leaking? Work safe around these vapors.
TC # 349
zdld17 is offline
post #8 of 13 (permalink) Old Aug 26th, 16, 09:48 AM
Vega$69's Avatar
Oil from the fuel pump is a long shot and I wouldn't start there. For oil to get in the fuel it would have to go past the diaphram. If the diaphram is leaking the pump won't pump.
Take the fuel hose off at the fuel tank. syphon a little fuel out. If dirty it's the fuel tank. If clean fuel in the tank then it's in the fuel line.
Next take the fuel line loose at the carb and crank the engine (pull coil wire off coil so it doesn't start) and pump some fuel into a clear container. If clear then it's just some residual fuel in the carb from time and your recent cleaning proceedure.
onefiness likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #9 of 13 (permalink) Old Aug 26th, 16, 09:55 AM
I stand corrected.
TC # 349
zdld17 is offline
post #10 of 13 (permalink) Old Aug 27th, 16, 05:59 PM Thread Starter
Chris M.
At this point I'm suspecting the fuel line from the tank to the pump is corroded. Gas in the tank siphons out clean, but the fuel in the lines between the tank and the pump is a dirty brown color. The fuel pump seems ok mechanically, so I don't think the diaphragms have failed, and the check valve in the fuek pump should prevent anything on the carburetor side of the system from getting back into the line where I found all the nasty fuel (between the tank and the pump).
The fittings on the line are metric, so maybe the lines are cheap after-market replacements prone to corrosion? The flare on the compression fittings also looks non-standard.
post #11 of 13 (permalink) Old Aug 28th, 16, 08:10 AM
Bud
What detergent did you use. I have not heard of that.
budro6968 is offline
post #12 of 13 (permalink) Old Aug 28th, 16, 12:01 PM
Steam cleaned.
TC # 349
zdld17 is offline
post #13 of 13 (permalink) Old Sep 17th, 16, 06:42 PM Thread Starter
Chris M.
Turns out it was just bad fuel. The stuff I siphoned off the tank turned a nasty shade of brown just a couple days after I collected the sample.
