TARGET MASTER CRATE MOTOR? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 4th, 04, 02:37 PM Thread Starter
Took the block casting numbers off the back of the block and found them to be this 10066036. When I did some research I came up with this
10066036
350
2 or 4
Target Master/Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
On the block pad there were only three characters on a very short pad that read 9 VP I know this is a replacement crate motor, but what other info can any one tell me about it? What year? HP AND TQ rating? 2 or 4 bolt main? How would I be able to tell? Trying to get as much info about the motor as I can. I figure there has gotta be someone who works for GM out there that may have access to this info. ANY INFORMATION WOULD BE GREATLY APPRECIATED!!
mark67ss is offline
post #2 of 3 (permalink) Old Apr 4th, 04, 05:40 PM
Bill
Mark,
That block casting number was used for over 10 years by GM for 350 engines. There is no reason to say it is a target block unless the engine code stamped into the front pad indicates so. It could be any 350 engine from about 1976-1988
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 3 (permalink) Old Apr 5th, 04, 09:54 AM Thread Starter
Hello Bill,
Thanks for the info. The engine has a very short pad on the front where the engine suffix code would be on 60"s blocks. The pad is only about 1 inch long. The only stamping on it is 9 VP . Thats it and thats all. The block looks pretty new. And the words HENCO DE MEXICO is stamped on the back near the block casting number. I assume that stands for made in mexico.
mark67ss is offline
