Engine Swap on a '94 - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 28th, 03, 05:51 AM Thread Starter
I have a '94 with 3.4 V6, 5 speed trans with 150K miles. The dealer told me that the crankshaft had too much play and when driven a bit hard the crankshaft sensor mulfunctions and causes the engine to idle high (2000 rpm). They told me to replace or rebuild the engine.
I would like to swap in an LT1 if I have to pull the motor. Has anyone done a swap like this? What do I need besides a new PCM and wiring harness? Does the 5 speed transmission bolt right in the back of the LT1? How much money do I need to budget for this? I am looking into a complete used LT1 hopefully with all the accessories with it.
imaflip1356 is offline
post #2 of 4 (permalink) Old Aug 30th, 03, 05:26 AM
might be better for you if you posted on a 4th gen board such as:
http://www.ls1.com
http://www.camaroz28.com
http://www.lt1tech.com
good luck.
MY FIRST 69 is offline
post #3 of 4 (permalink) Old Aug 30th, 03, 06:07 AM
DjD
DjD's Avatar
You'll need the tranny as your 5 speed won't bolt up. Also all the wiring and computers, different exhaust and drive shaft as well. A user running LT and tranny with all the wiring and computer will run you in the $3,500 - $5,000 range. Depending on your states laws you may never get the car smogged or licensed once you've done the transplant. Check out www.gmsports.com they have LT's in the $2000 range without transmissions.
...Dennis
DjD is offline
post #4 of 4 (permalink) Old Sep 2nd, 03, 08:36 AM Thread Starter
Thanks for the replies and pointers. It's a big help in making my decision.
