water pump and pulley - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 6th, 01, 09:08 AM Thread Starter
ok here is the problem. i just got my crank and water pump pulleys, the crank one went on just fine but when i went to put the water pump one on i would not work. the pulley rubs on the water pump and wont go on all of the way. what is the problem here?? should there be a spacer between the water pump and the pulley and if so how does the fan fit on the locater?? this is a 69 350
nate
cnred84 is offline
post #2 of 8 (permalink) Old Apr 6th, 01, 01:44 PM
I think you might have the wrong pulley for the water pump. I got a couple and one of the ones I have does the same thing. You need it to be not so wide, a shorter nose cone if that makes sence. Good Luck.
67stock is offline
post #3 of 8 (permalink) Old Apr 7th, 01, 01:36 AM
Joe
Cool
Wrong diameter water pump pulley, perhaps?
I'm going through the same thing on my 69 396.
Joe
69 396 w/SS Trim, B&M TH400, 3.55 12 Bolt Posi, Blue w/White Z28 Stripes, Chrome Rally Wheels
[email protected]
69 Pics http://albums.photopoint.com/j/Album...559&a=11674961
Joe G is offline
post #4 of 8 (permalink) Old Apr 11th, 01, 06:09 AM Thread Starter
so where would i go about finding a pulley with the smaller nose cone?? i took my brand new chrome pulley to the junk yard and was willing to part with it for one that will fit and they still could not find one. it is a remaned water pump and i got it from napa. now i am also woried that it will not fit in the engine bay with the fan and all on too. so where can i find the smaller nose cone pulley??
nate
cnred84 is offline
post #5 of 8 (permalink) Old Apr 11th, 01, 07:08 AM
Sounds like the rebuilder pushed on the hub to far not an uncommon occurrence you can take a small gear puller and move the hub so that the pulley will work
oger is offline
post #6 of 8 (permalink) Old Apr 12th, 01, 07:14 AM Thread Starter
Cool
no thats not it. the pump is too bulkey or something. it does not look like any other water pump i have seen.
cnred84 is offline
post #7 of 8 (permalink) Old Apr 12th, 01, 07:32 AM
David Pozzi
davidpozzi's Avatar
I think you have too late a pump.
they have a large diameter bearing and the housing is larger.
Look for a better pump or get your old one rebuilt.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #8 of 8 (permalink) Old Apr 20th, 01, 11:21 AM Thread Starter
Exclamation
the problem was i didnt have an old pump to have rebuilt. i got a new pump from autozone and it was the right one. but now napa wont take the other one back because i painted it already. so im out the money for the pump anyway.
nate
cnred84 is offline
