Carb Fuel Inlet Question/Issue - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 3rd, 16, 10:23 PM Thread Starter
Jon
Howdy all,
Got my new Q-Jet installed; 7047202 part number, Dec 1966 build, which should be right based on my car's Jan 1967 assembly date. I went to install the fuel line today, a 5/16 inch line. As you can see, that's too big. Most of the conversations I've seen have been about 5/16 versus 3/8. Obviously, 3/8 isn't the answer. My question - is something missing from the inlet on my carb? It's a rebuild I bought from a company called United Remanufacturing, and this is my first carbureted vehicle so I'm learning as I go.
Cheers,
Jon
67 RS, 327/275, PG
Born Sierra Fawn on Gold, now Bolero Red on Gold
Not sure how many owners, but she's mine now...
ScudRunner is offline
post #2 of 4 (permalink) Old Sep 3rd, 16, 10:42 PM
Smile Re: Carb Fuel Inlet Question/Issue
Check this out : Rochester Q Jet Fuel Bowl Inlet Fitting w Gasket 1" 20 Male 3 8" Line 5 8 18 Fem | eBay
http://www.oreillyauto.com/site/c/de...1166&ppt=C0075
Google - quadrajet fuel inlet
TJS69 is offline
post #3 of 4 (permalink) Old Sep 4th, 16, 06:14 AM
Seems like your rebuilder didn't provide the correct fitting. 5/16" line is correct for a 327/275 hp. That fuel inlet nut doesn't look correct. It's usually a much wider nut that you will need to hold with a wrench while you tighten up the fitting. Make sure you retain that white gasket as that is what prevents leaks and the temptation to over tighten resulting in stripped or cracked inlet threads.
1967 RS 327/275hp
trland is offline
post #4 of 4 (permalink) Old Sep 4th, 16, 10:28 AM
69-Pace's Avatar
Yeah Doesn't look like a Holly fitting?
You most likely need this fitting:
Quadrajet Parts Dot Com - 7/8 x 1/2-20 - Inlet Fitting
Fits:
Rochester Quadrajet carburetors
Fits Rochester 4G carburetors
Fits Rochester 2G carburetors
Carter / Edelbrock AFB, AVS carburetors
Carter WCFB carburetors
Holley carburetors
OAL: .650"
Thread length: .300"
Male Thread: 7/8-20 male
Female Thread: 1/2-20 female w/ inverted flare (accepts 5/16" steel gas line)
Quantity: 1 (Seal is included with fitting)
Replacement gaskets available:
#2231
Quadrajet carburetor note:
7/8" inlet fittings are found on all 1965 thru 1971 automobile and truck Quadrajet carburetors, plus all year marine Quadrajet carburetors.
7/8" diameter inlet carburetors can be identified by the location of the inlet gasket, it will be located up against the tightening nut of the inlet fitting. After installation of the 7/8" inlet fitting on the carburetor, the inlet gasket is visible.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
