Holley Plant - Team Camaro Tech
post #1 of 19 (permalink) Old Sep 3rd, 16, 11:29 PM Thread Starter
Donnie
Send a message via MSN to 69DZ302
Holley Plant
I've been having issues with my Holley 4053 carb on my DZ302 for awhile now and since I know nothing about working on it I was thinking about taking it to the Holley Plant in Bowling Green and just let them go through it and get everything in it replaced that needs to be and adjusted and ready to install on my car. I've tried to call several times but I have never been able to get anyone to answer the phone. I just need to know if I can deliver it in person or if I have to mail it. Has anyone ever had this place work on their carb that can tell me the phone number where someone will answer and how did you get it there?
Thanks,
Donnie
1969 Z28, Fathom Green, DZ302, M20, 3:73, PS, TW
69DZ302 is offline
post #2 of 19 (permalink) Old Sep 4th, 16, 12:14 AM
Tim
Re: Holley Plant
Donnie, I've never used Holley myself, but I can absolutely recommend Eric at Vintage Muscle Car Parts from personal experience. He's absolutely first rate, he knows these carbs inside and out, and does amazing work. He offers rebuilds as well as restoration services, pricing is very fair, and turnaround time was very fast on mine. Worth considering as an alternative, IMHO.
Eric's website is Vintage Musclecar Parts
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #3 of 19 (permalink) Old Sep 4th, 16, 06:21 AM
Matt
Re: Holley Plant
I recommend Eric at Vintage Muscle Car Parts as well. He custom built me a new Holley 1000HP for my big block. My carburetor flat out performs. His level of quality and attention to detail is second to none. He can also rebuild and modify stock carburetors so they perform better than new.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #4 of 19 (permalink) Old Sep 4th, 16, 07:17 AM
Rich
Re: Holley Plant
Jerry MacNeish also does very nice work on these carbs and his prices are very reasonable--assuming your 4053 is an original carb you want to have restored. He rebuilt my carb and distributor and the engine runs great. Holley offers a carb restoration service but I am not sure that it is in the Bowling Green plant. You can find info here: https://www.holley.com/customspeedshop/.
I don't want to sound negative about the service but it is pretty pricey. My dad a 67 Corvette tri-power set restored through this service to put on an L-88 short block that he found. The engine never ran quite right so I suggested that he open the carbs and check them out. There was debris inside and the floats on the 2 end carbs were set so that they would barely let any fuel into the carbs so he was only running on the center carb. Once he reset the needle and seats and cleaned out the carbs the engine runs awesome.
69 Z/28 RS clone. Azure Turquoise. First car--owned for 32 years and counting.
Rich Lordo is offline
post #5 of 19 (permalink) Old Sep 4th, 16, 07:24 PM
Vince
Re: Holley Plant
X2 Eric, he rebuilt the carb on my 69 Z/28 a number of years ago and did a superb job.
Vince
68 Camaro standard original 327 4 speed Laguna Blue black standard interior.
caldrovp is offline
post #6 of 19 (permalink) Old Sep 4th, 16, 09:40 PM Thread Starter
Donnie
Re: Holley Plant
Thanks for all the replies. It sounds like Eric is someone I will check on. If he does distributors I might check on that also. The carb is factory and the distributor, so it would be nice to have them both checked out and see if any worn out parts need to be replaced and set everything factory. Thanks again for all the replies and help.
69DZ302 is offline
post #7 of 19 (permalink) Old Sep 5th, 16, 06:24 AM
Andrew
Andrew69's Avatar
Re: Holley Plant
Vince
Same story for me.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #8 of 19 (permalink) Old Sep 5th, 16, 07:18 AM
Jonesy's Avatar
Re: Holley Plant
Eric has rebuilt at least 6 carbs for me. Stands behind his work.!!
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #9 of 19 (permalink) Old Sep 5th, 16, 02:07 PM
Lynn
Re: Holley Plant
Eric is the man.
Lynn
bilodeaulynn is offline
post #10 of 19 (permalink) Old Sep 5th, 16, 07:07 PM
Randy
Re: Holley Plant
Paul at SCS Performance Carbs does awesome work, he is in New York---detail is amazing.
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
post #11 of 19 (permalink) Old Sep 6th, 16, 07:42 AM
Eric
Re: Holley Plant
Vince
Originally Posted by Andrew69 View Post
Same story for me.
Originally Posted by bilodeaulynn View Post
Eric is the man.
Tim, Matt, Vince, Andrew, Mike and Lynn;
Wow, thank you all for the kind words, it's very much appreciated.
Donnie and I are in email contact, and after discussing the issues he's having with the car, I want to make sure his ignition system is dialed in before he sends his carb in--I'd hate to have him spend $ on his carb if that's not the problem.
Donnie, I'll get to your last email shortly.
Thanks again!
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
post #12 of 19 (permalink) Old Sep 6th, 16, 12:20 PM
Matt
Re: Holley Plant
Thanks again!
It's my pleasure to recommend you to others Eric. Quality workmanship should always be recognized.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #13 of 19 (permalink) Old Sep 6th, 16, 03:24 PM
Tim
Re: Holley Plant
^ couldn't put it better Matt
ZLP955 is offline
post #14 of 19 (permalink) Old Sep 6th, 16, 04:29 PM
Lynn
Re: Holley Plant
You bet Eric. My only complaint with the carb I got from Eric, was that is was so pretty, I didn't want to bolt it on and use it. Looked like it belonged in a display case.
Lynn
post #15 of 19 (permalink) Old Sep 6th, 16, 08:05 PM
Vince
Re: Holley Plant
That was my experience also, friends asked where I found the new carb.
Vince
caldrovp is offline
