full throttle lacks power - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 18th, 04, 12:08 PM Thread Starter
Hey fellas, i know its not a camaro but im pretty sure its the same engine...
I have an 86 Firebird V8 (305, carbed). When i go full throttle after the engine is warm the engine doesn't rev up, instead it bogs down and sounds like its about to die. When i let off the throttle a little and go 3/4 throttle it then revs up and takes off with alot of power. When the engine is cold and i go full throttle it works perfectly (i know this is horrible for the engine) and it revs freely and shifts where it should all the time having complete power. This tells me that it probally isnt the tranny, and is possibly the carb. Since it works when it is cold but not when it is hot it makes me think it may be that my fuel mixture is off. The engine also floods when i burnout which makes it die and i have to start it again.
Can anyone help me?
stope is offline
post #2 of 5 (permalink) Old Dec 18th, 04, 08:07 PM
How about just doing a *real* good tuneup, and having the carb rebuilt? Might do wonders for the little Camaro cousin. You may need to take it somewhere and get it checked out if its computer controlled, as a starting point, then look at performance enhancing products later. Got to have a healthy starting point however IMO. Good luck.
Rob
Robert
'69 X-33 since 1984
"Its all crazy..."
olympic69 is offline
post #3 of 5 (permalink) Old Dec 19th, 04, 04:41 AM
An '86 would be a computer controlled q-jet.
I second the tune-up & carb rebuild as an excellent starting point.
post #4 of 5 (permalink) Old Dec 19th, 04, 05:17 AM
Chad
67 Plum's Avatar
Be sure to replace the fuel filter.
67 Plum is offline
post #5 of 5 (permalink) Old Dec 20th, 04, 06:19 AM
If it is a Q-jet, it sounds like someone may have fiddled with the clock spring on the secondary throttle blades. Basically, the clock spring sounds like it is too loose and the secondaries are opening too far too soon. But I third the rebuild. Nothing like a fresh carb that is properly set up to start with.
dnult is offline
