3917291 Heads - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 5th, 16, 04:55 PM Thread Starter
Pete
3917291 Heads
I have a pair of 3917291 2.02/1.60 original GM heads. One is dated C/22/8
and came of a 68 z/28 302. The other one is dated I/13/8 and came from a 327 HO motor. They have been sitting around for quite some time and I just recently removed the rockers along with the rocker ball and nut and put them in a cleaning solution. I didn't pay much attention to what I was doing because both heads used 1.5 rockers, however the z/28 head had 'O' rockers and the other head just regular rockers. As I was cleaning the parts I noticed that I had 8 rocker balls of one thickness and 8 of another thickness. I don't think it makes much of a difference but when I put them back on the heads, I would like to put the correct 'balls' with the corresponding rockers. Do the thinner rockers go with the 'O' rockers or the regular rockers or visa versa.
Pete
pjbizjak is offline
post #2 of 3 (permalink) Old Sep 5th, 16, 06:56 PM
Re: 3917291 Heads
Not supposed to mix rocker arm and pivot balls , after they have been burned in. Its a pattern thing.
Need to pair them for he next user.
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old Sep 6th, 16, 11:22 AM
Will
wwallman's Avatar
Re: 3917291 Heads
Pete: Too late now to worry about trying to figure out which rocker arm went with which pivot ball. Don is 100% correct about the balls and rockers wearing in together. If you want to stay with the factory configuration order a new set of rockers and balls. If you by chance have screw in vs. pressed in rocker arm studs go the extra mile and go with a good set of roller rockers. Much more efficient as the motion is supported by needle bearings vs. stock rockers sliding metal to metal sections. As an added benefit you will pick up a few horsepower with a switch to roller rockers. Best of luck.
Detective Lt. Will, Chief of Homicide/ Chief Deputy Coroner: RETIRED AFTER 32 years.
67 Camaro RS /327 -275 hp
Powerglide to 2:73 rear gears
Black vinyl over Ermine White
30,000 documented mile survivor
Second owner. P.O.P car.
wwallman is offline
