402 BB Stroke Change - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 6th, 04, 06:54 PM Thread Starter
I was kicking around the idea of replacing the stock cast 3.76" stroke crank with a 4.00" stroke forged crank for more low end torque.
Has anyone done this before and what kind of mods will this require? (Block Clearancing / Custom Pistons)
I would be using the original 113cc open chamber heads and stock rod length. I was looking for a 10.5:1 compression ratio, but would the Speed Pro domes be too much for the stroke increase?
Any comments are appreciated!
Camaro Purgatory
67 BB Vert - in pieces
67 RS SS - in pieces (but less than before)
67 Pieces - in pieces
sci-flyer is offline
post #2 of 2 (permalink) Old Apr 7th, 04, 08:13 AM
Cool
If I was to go to all that trouble, I would try a 496 crank in it b/c some of the blocks can take the 4.00" crank fine and if so, I bet a 4.25" crank will fit too!!
Anyway, it may be worth looking into if you DON'T want to use a 454 block, but still want to max. your cubes...
pdq67
