transmissions - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 25th, 01, 03:25 PM Thread Starter
I am putting a built up 355 in a 1983 camaro and I am not sure as to which kind of transmission I should put in it. I have a 700-R4 that came out of a 1983 S-10 and a TH-350, not sure what it came out of though. If anyone could give me their thought about my situation I would greatly appreciate it a lot.
please contact me by email: [email protected]
Thanks,
spyder_350 is offline
post #2 of 7 (permalink) Old Feb 25th, 01, 04:16 PM
I hate to tell you this but that 700 out of the S-10 has a different bell housing bolt pattern than your 350.
If you're building a driver I would go for the overdrive.
The 700 is a good tranny if you don't try to put too much power through it. I like mine.
The 200R4 is about the same size as a TH-350 and can take more power. You might try digging around the junk yards for one.
Stephen
67 RS/SS 350 700R4
69 SS clone unfinished
72 454 Weekend Racer
squarles is offline
post #3 of 7 (permalink) Old Feb 25th, 01, 05:47 PM
If you deside that you want a 700 r4 which is what I would put before a th350. In my experince I believe that if it came from the 4.3 It will bolt up. Call a trans shop to make sure but I think it will.
Shane
sweems is offline
post #4 of 7 (permalink) Old Feb 26th, 01, 09:20 PM Thread Starter
I am wondering what would be the best and cheapest performance mod i could do to a set of stock 350 heads. I have a 350 bored .030 over, performer rpm intake, mild cam, 650 cfm carter carb. This is going into a 83 camaro. Can anyone help?
Thanks,
post #5 of 7 (permalink) Old Feb 27th, 01, 07:46 PM
SID
Lightbulb
HEY THERE
S-IO WILL NOT WORK. YOU NEED IT FROM A CAMARO OR FIREBIRD OR CHEV ASTRO VANS WITH 4.3 . THE DIFFRENTS IS CAMARO AND FIREBIDS HAVE THREE BOLT HOLES IN THE TAIL STOCK OF THE TRANNY FOR YOU TORQUE PLATE AND THE CHEV VANS HAVE THE SAME THREE BOLT HOLES FOR A COUNTER WEIGHT IT WILL WORK ......SID
SID is offline
post #6 of 7 (permalink) Old Mar 1st, 01, 02:57 AM
Lightbulb
[If the 700-R4 cam out of the 4.3 it will fit the bolt pattern is the same ,a 4.3 is the same thing as 350 with two cylinders cut off the front of it.Plus the 700-R4 is good up to about 450 HP i doubt you will be pushing that much without adding nito!and it has a lower first and second gear than the 350-turbo.And it is lighter!
T/A GTA is offline
post #7 of 7 (permalink) Old Mar 1st, 01, 02:58 AM
<BLOCKQUOTE>quote:</font><HR>Originally posted by T/A GTA:
[If the 700-R4 cam out of the 4.3 it will fit the bolt pattern is the same ,a 4.3 is the same thing as 350 with two cylinders cut off the front of it.Plus the 700-R4 is good up to about 450 HP i doubt you will be pushing that much without adding nitro!and it has a lower first and second gear than the 350-turbo.And it is lighter!<HR></BLOCKQUOTE>
T/A GTA is offline
