Need help with headers selection - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 8th, 16, 06:56 AM Thread Starter
Tim
I have a 69 camaro with a sbc 383 stroker with aluminum heads, 4 speed Muncie, power steering, no a/c. I'm looking for full length headers, preferably ceramic. Looking for recommendations on a set for best fit and performance without breaking the bank. Thanks
Weltertm is offline
post #2 of 10 (permalink) Old Sep 8th, 16, 07:16 AM
Darin
ilikeike's Avatar
Re: Need help with headers selection
Dynatech and Doug's seem to fit well on first gens,
Hooker has a new design for camaros that is suppose to be much better than their old design.
They all seem to be around $700 coated.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #3 of 10 (permalink) Old Sep 8th, 16, 07:17 AM
Vega$69's Avatar
Straight or Angle Plugs?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 10 (permalink) Old Sep 8th, 16, 07:28 AM Thread Starter
Tim
Straight plugs
Weltertm is offline
post #5 of 10 (permalink) Old Sep 8th, 16, 07:52 AM
Vega$69's Avatar
Hooker
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #6 of 10 (permalink) Old Sep 8th, 16, 08:28 AM
When selecting headers a few things to consider are size and application. Race only won't have an exhaust system so it won't have header flanges to bolt on a reducer for the four inch diameter collector. I know the NHRA requires mufflers now but if you have ever seen a NHRA approved muffler it looks to be the size of a CAT and has a straight through four inch hole that doesn't really do anything other than comply with the rules.
Racing headers are made of equal length tubes and the length of the primary tube and the collector are tuned to the power band that the motor makes peak power The headers are shipped with a slip fit tube not welded together so that you can tune to length before welding them up. This is done to scavenge the exhaust gasses out of the cylinders just before the exhaust valve closes (selecting the cam's exhaust duration is part of the tuning process). A standing wave will only exist in an open pipe. That is why pipe organs have open pipes and not Flowmaster or Dynomax mufflers on the top. Install a muffler or a pipe that is too long for the frequency of the wave and you get nothing as far as scavenging goes.
There is another affect that makes a header more useful than a cast iron manifold and that is in segregating the exhaust pulses. You can think of the exhaust not as a steady stream but as a series of hot high pressure plugs of gas trying to escape to a lower pressure area (entropy in action). If you have a cast iron log manifold and it is attached to a small block Chevy then cylinders five and seven are firing sequentially (bang-bang). As such cylinder seven is attempting to close it's valve as cylinder five dumps another plug of hot gas into the log manifold. That creates an area of higher pressure outside of the open exhaust valve in cylinder seven allowing exhaust gases to flow past the not yet closed valve. This dilutes and reduces the volume of the next incoming charge of fuel and fresh air. Contrary to what the EPA thinks introducing exhaust gasses into a running engine interferes with combustion, as well as their desired goal of lowering emissions.
By making the length of your pipe(s) between cylinders five and seven eighteen inches long or longer you can prevent that cylinder contamination from happening (Nine inches pipe on both cylinders accomplishes this, or some combination of length to the collector and back again). How much depends upon the volumetric efficiency of your engine; but up to twenty five horses have been recorded on dyno tests of no other change than just bolting on a set of long tube headers in place of cast iron manifolds.
In terms of generalities the bigger the primary tube the less likely the headers will fit your car without a lot of swearing and possibly modification of parts. The gain is to peak horsepower with a larger primary tube diameter, at the expense of bottom and mid range torque. The converse is the smaller the primary tube the more bottom end and mid range torque you will retain for street driving at the expense of total horsepower. A smaller tube header will fit with out near as much fuss as it takes up less room under the hood.
Ceramic coated headers (if coated inside and out and not just on the out side) will make more power and last longer than un painted mild steel headers of the same size. This is due to the heat being moved out of the engine bay with out first preheating the under hood air to increase the air density. The ceramic coating (water glass) insulates and reflects the heat back into the gas placing it further back in the exhaust system where all it can do is heat up the floor under your feet and increase the heat in the gas lines.
Big Dave
Larger Dave is online now
post #7 of 10 (permalink) Old Sep 8th, 16, 08:28 PM
Chris
Dynatech! I have them on my 302 and they clear the PS with no hammer work. Also, I'd never buy headers that didn't have a ball and socket style connector at the collector; sure beats having to perfectly align two flat flanges with a gasket. Transition connectors from the collector to the exhaust pipe are made of stainless.
ctcz28 is offline
post #8 of 10 (permalink) Old Sep 8th, 16, 10:18 PM
Doug
Here is a link to a set of Hooker headers and a set of Dynatech headers. https://www.summitracing.com/parts/d...t/model/camaro https://www.summitracing.com/parts/h...t/model/camaro Be your to check your exhaust ports for the shape before ordering headers the Dynatech are oval shape ports and the Hookers are D shaped ports. You didn't say what brand of heads you have only aluminum.
camarodriver67 is offline
post #9 of 10 (permalink) Old Sep 9th, 16, 01:20 AM
Cory
I have a Big Block so not sure how it will for on yours - BUT Flowmaster makes some Nice Stainless coated headers for a fantastic price! I have long tubes and they fit well for me. Give them a look
1968 Firebird - Gen IV 496 Stroker - TH400 - Caltrax rear suspension system w/slider boxes - Corporate Posi Rear with New Axel's - Long Tube Headers, Pypes Race Pro Dual Exhaust and Lotsa other Goodies =)
Arkangel77 is offline
post #10 of 10 (permalink) Old Sep 9th, 16, 06:43 AM
Another vote for Dynatech, very high quality and ceramic jet coated both inside and out with a ball and socket collector setup. They aren't the least or the most expensive headers available but as far as value goes (cost for what you get), they are right up there.
NH69Z28RS is offline
