Lifting Engine from Underneath - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 7th, 03, 04:09 AM Thread Starter
Misha
Ok, so it's easy to change engine frame mounts.
Do I lift the engine by the oil pan, balancer or do I use the front lip of the engine where the oil pan meets the block by using 2x4's?
Any takers???
69 Camaro Z27
69ss350 is offline
post #2 of 4 (permalink) Old Sep 7th, 03, 05:15 AM
I just put a 2x6 under the oil pan and jack it up. Make sure the board covers the pan from side to side.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #3 of 4 (permalink) Old Sep 7th, 03, 08:11 AM
Vintage 68's Avatar
69ss;
Read through this thread for engine jacking info;
https://www.camaros.net/forum/ultimat...=010698#000001
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 4 (permalink) Old Sep 7th, 03, 08:11 AM
click's Avatar
There was a discussion about this awhile ago, probably in Engine section , my mechanic pushed up on the balancer with a rod thru the frame hole right below it. Others said that can ruin the seal and cause other harm, now just yesterday I was reading my new chassis service manual that I just got and it showed the photo and gave directions for doing that exact thing.
Im guessing that using the edges of the pan as mentioned is just as easy but Chev even describes how to use the balancer. Do a search on 'lifting engine' or 'changing mounts' and you will read lots of opinions on the subject.
good luck
[img]graemlins/thumbsup.gif[/img]
click is offline
