350 gushing oil... rear main seal? - Team Camaro Tech
post #1 of 18 (permalink) Old Jan 29th, 05, 08:39 PM Thread Starter
Jeff
Guys,
Got a 93 chevy truck 350/700r4. Gunned it a little to get into the driveway (snow) and got out to see a pool of oil under the back of the engine. I started it back up and oil just came pouring out of the back of the engine.
Could this be the rear main seal? I read somewhere that the rear main seal isnt exposed to oil under pressure, so higher oil pressure wouldnt have caused the rear main seal to bust. Is this true?
Can you guys help me figure out what it is?
thanks
jks67SS396 is offline
post #2 of 18 (permalink) Old Jan 30th, 05, 02:43 AM
Someone steal your oil filter?
and
Brian Lewis is offline
post #3 of 18 (permalink) Old Jan 30th, 05, 05:56 AM
Chad
67 Plum's Avatar
Like Brian said check the oil filter or sending unit on the back of the block.
67 Plum is offline
post #4 of 18 (permalink) Old Jan 30th, 05, 07:09 AM
Bill
jk,
Those trucks are famous for the oil cooler lines breaking.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #5 of 18 (permalink) Old Jan 30th, 05, 07:36 AM Thread Starter
Jeff
Oil filter is there and tight. oil cooler lines? are those the lines coming into the oil filter plate?
thanks
1967 SS 396, M20.
now a 10.4:1 540, AFR 315 heads, UDHarold SR Cam with a Tremec TKO
post #6 of 18 (permalink) Old Jan 30th, 05, 07:40 AM
Chad
67 Plum's Avatar
Yes that is them.
67 Plum is offline
post #7 of 18 (permalink) Old Jan 30th, 05, 07:52 AM
i had a 90 pickup that had an oil sending unit on the side of the block(drivers side near the oil pan).this is the sending unit for the oil pressure guage.mine totally blew apart and oil was spewing out.might want to check that out.
emtcee1973 is offline
post #8 of 18 (permalink) Old Jan 30th, 05, 08:11 AM
Our old '97 chevy truck had leaks at the oil cooler lines near the filter also. It always left drips under the truck.
supv26 is offline
post #9 of 18 (permalink) Old Jan 30th, 05, 08:17 AM Thread Starter
Jeff
ill check this stuff out... but this was gushing out. looks like when you drain the oil out of the pan... does the rear main seal leak like that?
thanks
1967 SS 396, M20.
post #10 of 18 (permalink) Old Jan 30th, 05, 08:22 AM
stevo camaro's Avatar
Gunning it thru the snow in San Jose? [img]smile.gif[/img]
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #11 of 18 (permalink) Old Jan 30th, 05, 01:15 PM
Unhappy
Sh-t!!
A LEAKY oil sending unit!!!
You know way back when, the old '60's Corvairs used to have this problem AND I woulda thought GM woulda fixed it by now!!!
BAD, BAD, BAD!!!!!!!!
pdq67
post #12 of 18 (permalink) Old Jan 30th, 05, 03:19 PM Thread Starter
Jeff
well,
I got back under there and although i didnt fire it up, i did see that the oil sending unit and both oiler cooler lines are bone dry...
what else is up in between the engine and bellhousing that could be leaking oil? the top of the engine is bone dry too...
would the rear main seal leak like that (gushing out)?
thanks
jeff
1967 SS 396, M20.
post #13 of 18 (permalink) Old Jan 30th, 05, 04:00 PM
Bill
j,
The rear seal is not under pressure so it really should not be "gushing" out as you are describing it. Is it possible the oil filter gasket got pushed out ? I really think you are going to have to start it to see where it is coming from. There is really nothing in the back of the engine that would come out easily and cause a leak like that. There are three oil galley plugs, but they are screwed in place and impossible to get out even when you want to, so I doubt that one of them is causing it.
Stupid question, but are you sure its engine oil and not trans fluid ?
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #14 of 18 (permalink) Old Jan 30th, 05, 04:14 PM
bill has a point, are u sure its not tranny fluid?i know in my truck someone didn't tighten down the front pump on the trans and fluid was gushing out like crazy.it leaked from the bellhousing inspection cover.
post #15 of 18 (permalink) Old Jan 31st, 05, 01:39 PM
Bob
Hey bill
I had same problem.
Check the back of manifold and back of oil pan gasket. I ended up with plugged pvc valve and the pressure blew both oil pan and manifold gaskets. The gushing came mostly from back of manifold couldn't find it till I removed engine to replace rear main seal and back tracked the wet source to points of origin. It poured down inside of bell housing. It made it look like it was coming from the rear main seal. Found mine after I removed engine.
Good luck
MT 68 conv
MT 68 conv is offline
