Spacer length between pump pulley and flex fan?? - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 16th, 03, 06:09 PM Thread Starter
How long of a spacer can I safely use between my 5 blade flex fan and the water pump/pulley? I currently have a 2 inch spacer. My flex fan is not completely inside the shround. It actually is right on the edge of being outside the shroud. I was told that if the fan is all the way inside the shroud, the motor will run cooler. I have a short water pump on a small block engine with a 3 core OEM radiator. The shroud is a reproduction type from NPD.
supv26 is offline
post #2 of 3 (permalink) Old Oct 17th, 03, 03:09 AM
Eric
I believe the correct position is 1/2 inside - 1/2 outside of the shroud. If the fan is all the way in the shrould the gap between the edges on the fan and the shroud is bigger --- closer to the radiator doesn't make any real difference.
Just add enough spacer to put the fan 1/2 in - 1/2 out of the shroud. Barely fully inside the shroud is OK too.
And whatever you do make sure you don't get your fan too close to that radiator - especially with a flex fan. First time you rev it up that fan could flex right into your radiator.
Eric68 is offline
post #3 of 3 (permalink) Old Oct 19th, 03, 04:19 AM Thread Starter
Angry
Thanks for the info Eric!!
[img]graemlins/beers.gif[/img]
supv26 is offline
