Tell me if yall think this is low oil pressure at idle in gear - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 7th, 01, 07:19 PM Thread Starter
well its a 400 small block and when i first start it my oil pressure is like 65 but once it warms up it is 25 pounds in (park) and once i put it in gear it drops to 17 pounds of oil pressure , but going down the road it sits on about 50 do u think that is bad for a small block chevy? thanks for the help
(has 20k on it and doesnt smoke or any thing like that and o yeh is it true that a high volume oil pump on a 5 quart oil pan will suck the oil pan dry , i also heard that lifters have a metering device that controls how much goes up to the motor) .
camaro79tx is offline
post #2 of 11 (permalink) Old Mar 7th, 01, 07:28 PM
DjD
DjD's Avatar
How hot is your engine running? What oil are you running? I really don't think you have a problem unless pressure drops off when reving or under load. If you're getting 10psi per 1000rpm or better and your lifters are staying wet (no clacking) and the pressure climbs when reving it don't swet it!!
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #3 of 11 (permalink) Old Mar 7th, 01, 07:50 PM Thread Starter
it runs pretty cool about 160 to 170 but when i rev it the pressure goes up and every thing and no clacking this a 13 second car not real fast but fast for the street , and was also wanting to know is it possible to suck oil pan dry with a high volume oil pump on a 5 quart oil pan huh? cause thats what we put on mine
post #4 of 11 (permalink) Old Mar 7th, 01, 07:51 PM Thread Starter
o yeh 40 wieght pennzoil with a additive
post #5 of 11 (permalink) Old Mar 8th, 01, 03:42 AM
Its just a loose motor. Mine will drop below 20 PSI at about 900 RPM idle. As soon as you come off idle the pressure shots right up.
I would not worry...
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Member of the "unwanted" 3rd Gen group.
Mark W. Winning is offline
post #6 of 11 (permalink) Old Mar 8th, 01, 07:25 AM Thread Starter
alright thanks for yalls help
post #7 of 11 (permalink) Old Mar 8th, 01, 08:28 AM
What does it mean if the pressure drops under a load?
Firebird411 is offline
post #8 of 11 (permalink) Old Mar 8th, 01, 11:06 AM
Lance
Mark is right. If it goes up with the revs you're OK. The rule of thumb is 10 psi per 1000 rpms.
Spitfire44 is offline
post #9 of 11 (permalink) Old Mar 8th, 01, 11:56 AM
camaro79tx,
I have the same "issue" in my 67 with a 72 350. I installed a Melling high volume/high pressure oil pump two years ago. Pressure is at 65-70psi at cold startup, hot (temp stays at 180-190 degrees) driving is at about 40-50psi and hot idle is at about 15 psi. Been driving this everyday since I put the pump in with the stock oil pan and haven't had any problems whatsoever. I've taken several 600+ mile trips in it too, without any issues. I am not worried, and I think you should be fine too.
Justin
-1967 Camaro SS350
www-student.furman.edu/users/j/jtrauner
jrt67ss350 is offline
post #10 of 11 (permalink) Old Mar 8th, 01, 01:22 PM
My brand new 383 is like 65-70 cold at startup,40-50 around town, and 19-20 at idle,in park after warmup too. You'll be fine.
383 Speed-O-Motive stroker kit with Speed Demon 750, RPM intake,Proform HEI dist.MSD6a box,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves,64cc,TRW forged pistons with 10.7:1 compression, Comp Xtreme 284 cam,Crane pushrods, Comp Cam 1.6 full roller rockers,ATI damper, 40 series Flowmasters, 4.11 gears with TH350 and 3000 stall.Powertrax NoSlip Locker
Tracy Focht is offline
post #11 of 11 (permalink) Old Mar 8th, 01, 06:19 PM Thread Starter
glad to here every one elses oil pressure is around mine to i was worried well thanks every one.
