What Studs do I need? - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 17th, 16, 05:41 PM Thread Starter
Ken
I was given these and want to use them but I am short 2 studs because my setup uses short studs on the outside for the plug wire seperators. Any one know what studs I need and who has them?
68 SS 383 Stroker w/ TKO 600
12 bolt 3.73
AlotHP68 is offline
post #2 of 8 (permalink) Old Sep 17th, 16, 06:21 PM
Re: What Studs do I need?
1/4"-20 by the length you want/need.
I made my own using all-thread, a cut-off wheel, and a nut to straighten the threads after cutting.
You can also buy what you need in most parts stores.
68 Camaro~LSx ~all motor
post #3 of 8 (permalink) Old Sep 17th, 16, 08:55 PM Thread Starter
Ken
perfect. Thanks!
12 bolt 3.73
AlotHP68 is offline
post #4 of 8 (permalink) Old Sep 18th, 16, 06:19 AM
Andrew
Andrew69's Avatar
Get some allen head set screws in the length you need. Good quality stock and no cutting.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #5 of 8 (permalink) Old Sep 18th, 16, 07:24 AM Thread Starter
Ken
How would that work if the piece I pictured has is threaded?
12 bolt 3.73
AlotHP68 is offline
post #6 of 8 (permalink) Old Sep 18th, 16, 07:37 AM
Andrew
Andrew69's Avatar
One end screws into your T-Handle thing the other to secure the valve cover. Your local hardware store will have them.
X10 Pcs 1 4 20 x 1" Stainless 304 Steel Socket Set Screw Cup Point End New | eBay
Unless I am misunderstanding your need.....
Skunk Works
Some photos:
Member # 159
post #7 of 8 (permalink) Old Sep 18th, 16, 04:11 PM Thread Starter
Ken
oh ok I gotcha now. Didnt know what you meant by the allen head part.
Thanks!
12 bolt 3.73
AlotHP68 is offline
post #8 of 8 (permalink) Old Sep 18th, 16, 05:00 PM
That'll work too
