hooking up a vacuum gauge - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 17th, 16, 07:44 PM Thread Starter
Dean
islanddean's Avatar
I have a remedial question. How/where do i hook up a vacuum gauge on small block 327?
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
islanddean is offline
post #2 of 5 (permalink) Old Sep 17th, 16, 07:56 PM
Nick
I connect mine to the vacuum port on my carburetor.
Nicc21 is offline
post #3 of 5 (permalink) Old Sep 17th, 16, 08:10 PM
re: hooking up a vacuum gauge
If you connect it to the port on the metering block you will not get any vacuum until the throttle blades open (this is called ported vacuum) If you connect it to a nipple in the base plate of the carb you will get full manifold vacuum all of the time.
Big Dave
Larger Dave is online now
post #4 of 5 (permalink) Old Sep 17th, 16, 08:21 PM
Nick
I connect it where my pcv valve goes on the front of my edelbrock carb. Hopefully that is the right spot for a good reading?
Nicc21 is offline
post #5 of 5 (permalink) Old Sep 18th, 16, 08:48 PM
Re: hooking up a vacuum gauge
On my 70 LT1, I tapped a couple of spots on my brake booster aluminum fitting.
COPO is offline
