406 Opinions & Power Level - Team Camaro Tech
post #1 of 4 (permalink) Old May 5th, 04, 05:30 PM Thread Starter
Would like to hear your opinions on this 406 build up. Block 30 over,decked and line bored. Stock crank cut 10/10 rods and mains. Forged pistons and 5.7 rods. All internally balanced. 10.0 to 1 compression. Dart Pro 1 200 aluminum heads (the heads are the choise of the engine builder - he is friends with Richard Maskin and gets very reasonable pricing). CompCams 286H cam (236 duration and 490 lift). Original Z/28 hi-rise with Speed Demon 750 card. MSD dist/6a box. I'm looking for 500 ft/lbs of torque and near 450 H/P. All I need is enough vacuum for a brake booster. Am I close? If not what would you change? Thanks in advance for all you comments and/or opinions.
Jack
JV69z/28rs is offline
post #2 of 4 (permalink) Old May 5th, 04, 06:14 PM
Matt Jones
That should produce excellent power. A bit more lift would be better (I'm running .550" lift), but should make great power regardless since those heads flow pretty well. Add on some 1.6 rocker if you can.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #3 of 4 (permalink) Old May 6th, 04, 02:13 AM
Smile
You might talk to your motor builder about going with about the same size solid cam so that you can pick up more power everywhere, imho if you don't mind lashing it every so often..
Jmho.
pdq67
PS., that's why I went with CC's, 282S solid cam in my big motor..
post #4 of 4 (permalink) Old May 6th, 04, 04:13 PM
Greg
Or a roller cam! [img]graemlins/thumbsup.gif[/img]
If you want 500 ft/lbs a roller will help dramatically.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
